Can not set up. on connection, either wireless router works or the PC which has a wired modem connected to broadband. Pl guidemy mail mee.ratan@gmail.com thanks
  • 62 Answers
Okay do this.
go to 192.168.1.1
username it's in blank (no password) if that doesnt work try with admin as a username.
the password it's password, if it doesnt work try with admin as a password,
You'll see a linksys page, to the top you'll see the wireless set up.
Click there and change the name and the password.
After you do that save the changes and you'll see the difference :) on your wireless connection it's like creating a new connection, you can always change the channel for a better signal too ;)
Posted on Apr 27, 2010
Hi I am using reliance broadband. They have
Easy, if your modem is connected to your computer right now and internet is working all you need to do is connect your LAN line to your belkin router. the connection should say input, or Internet. after that you will need another LAN wire (These look like telephone cables but the jack plug is larger and will only fit a lan connection on your router or computer) Connect the second wire to the line 1 or outout 1 from your router, to your pc in the slot where the other cable was connected. your internet signal should work.... on your mobil find any available network and log in to your belkin router.
that should do it.... if you haven't set up your internet connection, do that first by installing the drivers for the modem provided by your provider and then complete the process above.
Oct 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Will not connect to internet whether it is wired or not
connect the broadband modem to the internet port of your router (probably is blue). Then connect your pc to the router.
You have to set your router to act as dns.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I have a Dynamode wireless router which i have configured however the cable which came with it does not fit into telephone connection. What other cable do i require
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
Sep 08, 2009 | Computers & Internet
I need help connecting my router. I am so confused.
Check with my tip.
Be sure you can browse internet using existing Modem connection (hispeed)
correctly follow instruction to connect router WAN port to modem.
Connect a PC to Router and follow instruction to config it
Jan 09, 2009 | Dynex Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Router works with wire not wireless
there are lots of thing ht can be done like enviroment chek
wep key config ,firewall setting, go one by one minimize the firewall then try to ping it
to to network connection set it up again
this time with proper wep key and in enviroment make sure ur router is not near a carpet or microwave or any plant
May 22, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
