Question about Toshiba Satellite 1805-S204 Notebook
Flashing Toshiba satellite 1800-S204
I've tried a lot of software flashing utilities, but only error messages i get as an result, no progress.
The real problem is that the bios wont recognise the hard disk any more, it was not replased, and it works good as an USB connected on my other computer. Ive checked the hard disk , did FDISK /Cmbr 2 to check the master boot record and evenmade an HD image from a syster computer (same Brand ) and forced the image from that HD on this one. but stil the bios wont "See" it, i'm suspecting an virus, cause when i put the HD before i cleaned it in an other laptop the other on also stoped booting and giving me the same message "C drive not detected." or something like that.
Any suggestions?
  • DanserMax Mar 23, 2008
    Thank you, for the interest . it gives me the feeling not being alone out here struggling for an sollution.
    Additional information requested follows.
    Model Computer Toshiba Satellite 1800-S204
    MotherBoard(mobo) ????????
    Bios original ACPI version 1.10
    Bios Downloaded ACPI version 2.10
    Cmos Information (only relevant)
    HardDisk Mode = not used
    Boot Priority = HDD => FDD => CD-ROM => LAN
    Power On Boot Select = Enabled
    HDD = No Drive
    CD-ROM = Secondary IDE (170H/IRQ15)
    Floppy Disk = (3F2H/IRQ6/CH2)
    Build-in LAN = Enabled
    I am basically an Computer Programmer,but used to help neighbours colleges and or friends whith their computer related problems free of charge of course.
    Normally it doesnt take more than a day or two to fix one. Used to go to the Registry and scan out the threats manually.
    But now with this one i'am in big trouble an need help urgently.
    What i;ve done already
    downloaded and burn on a bootable CD windows and DOS routines like snapshot.exe (Works Like Ghost) to make compleet image of an HD.
    And HD Tune 2.52 to scan HD disk surface for damaged blocks
    connected the HD to an USB to IDE /SATA cable and backed up the data on my Computer then I've formatted the HD zero filled it and trieid again , no luck kept searching the internet for infos found out about Fdisk MBR command and bingo managed to clean the HD then but stil no luck for the computer to recognise the HD.
    So i thought let me Flash the BIOS and get rid of every thing. Start with a clean HD and clean bios/cmos.downloaded routines like bios.exe , xbios.exe, uniflash.exe and the new bios from the toshiba site. and here i am now unable to flash the bios because when a program tries to overwrite the area the the threat is protecting an message apeares "the file XXXXX.bin can not be found on diskette" . of course this is an misleading message. what happens is the threat stop execution of the flashing program and then send that misleading message.
    What i need from you.
    Either a way to show me the running tasks in dos.
    then a routine, program that enable me to stop the treath from executing first then i'll be able to flash, or a route that enables me to flash true the threat.
    It istablish himself on two places First Somewhere in the MBR area.
    and in the bios but the boot area of the bios. it accept normal flashing of the cmos area but when you tries to replace the boot area command/instructions from the bios you'll get an error message "the file XXXXX.bin can not be found on diskette"
    Hope to have imform you enough.
    thank you for your time
    An expert whose answer gotĀ voted for 100 times.
  • 156 Answers
You query did not give any clues abt the PC/Motherboard and its BIOS revision.
That said if the PC/BIOS will not "see" the HDD then its is unlikely a cause of a virus.
Some old motherboards can't recognise a HDD if its size is more than 137GB. Some older motherboard also require than you set the HDD jumper correctly (Master or Slave).
At this stage, i am assuming the HDD in question is PATA or IDE (Old Spec). If the HDD is SATA (New Spec), then you will need a SATA port to connect the HDD. Ensure not to use both "old" molex power connector and "newer" SATA power connector together.
If the HDD is SATAII but the SATA spec for your motherboard is SATAI (initial spec), some motherboards and SATAII drives require that you jumper the HDD to allow it to work at the lower SATA speed.
If none of the above points apply try upgrading your system BIOS of the latest version. Also review the mortarboard's manual for more info.
Posted on Mar 23, 2008
Reset Satellite 1800-S207 to factory settings
its in the manual, lost it?
if yes, go to their web page, and read it there.
Toshiba , dot , com.
always there, and ready.
Oct 01, 2013 | System Integration Business Brand 160GB...
Toshiba sattelite 1800 usb2
No. This unit has USB 1.1
USB 2.0 did not come out until about a year or so after this unit was made. You can however use an expansion card in the pc card slot to upgrade it to USB 2.0.
Jun 14, 2010 | Toshiba Satellite 1800-S204 Notebook
Why its not so easy to download the toshiba drivers? Sales fell [robably!
dear download software"Uniblue Driver Scanner" it will scan your system driver and install them.............
Nov 05, 2009 | Toshiba Satellite 1800-S204 Notebook
Diplay Toshiba Satellite 1800-S204 Laptop
you need to contact TECH SUPPORT to get the CD driver , I own myself a TOSHIBA SATELLITE and needed to install the driver but the only way to do it is thru the CD that came with the unit.
Sep 22, 2009 | Toshiba Satellite 1800-S204 Notebook
Satilite 1800 3 beeps no boot 1 long 2 short
That is a memory error. Remove and reseat the memory in your computer. If the error persists and you have more than 1 stick, try each stick separately to find the faulty unit. If you only have one stick, then the memory will need to be replaced.
Jun 30, 2009 | Toshiba Satellite 1800-S204 Notebook
Same toshiba Satellite will not flash problem,,,,,
Thx for the reply. I think for the meantime we will stict with the BIOS upgrade first. When done then we can sheck out the HDD.
Have you tried the BIOS by Floppy sticking with Toshiba's utility.
The current BIOS v.1.10 is Initial BIOS for Satellite 1800, download ACPI Flash BIOS version 2.10 for Satellite 1800/1805-Sxx4 - from a Windows PC. Run "1183v21.exe" to extract the files to a folder. Check the readme file for installation info
****Extract from ReadMe File******
A DOS batch file, INSTINFO.BAT is provided in the ZIP archive which will create the BIOS installation diskette.
If all else fails, you can execute the self-extracting diskette image manually. This file is named 1349D21.EXE , and needs a parameter of A: (1349D21 A:) to successfully create the diskette in drive A:
Mar 24, 2008 | Toshiba Satellite 1805-S204 Notebook
Toshiba Satellite 1800-911 DRIVERS
try this one:
Sep 26, 2007 | Toshiba Satellite 1800-S204 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
278 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
