Maxtor one touch 750 I/O error - Computers & Internet
  • 2 more comments
  • drewmckaig Apr 23, 2010
    we are using Vista now. the maxtor has been working fine until today?
    reload drivers after the 1st error message earlier and it seemed to work fine again.
    then tonight it is showing error again, and not reading drive. tried hooking to our laptop and it does not read maxtor drive either? there are very important files on there.
    It showed that the files are there, just not reading them. Any ideas?
    my maxtor 750gm external storage device is not being recognized by the PC running on Vista.
    has been working fine until today, now saying I/O error.
    we reloaded the drivers earlier and this did not help.
    we tried on two other devices not working;
    President:
  • 1,070 Answers
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date.
  • Access "Control Panel" from the Start menu and then choose "Performance and Maintenance."
  • Click "System" and then go to the Hardware tab and click on "Device Manager."
  • Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Next Step to enable it.
  • Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware.
  • Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
Thanks for Contacting FixYa...
Posted on Apr 23, 2010
  • shafi
    shafi Apr 23, 2010
    Have you Tried Enabling /disabling Feature by Going to Device Manager...
    OR Completely Remove its Driver From PC >Reboot PC >Then Reload Driver >Then Check out
    Still problem exist..
    >Check it on Other PC(If it is OK in Other PC ,Then make System Restore(Reload OS) and install driver if needed after Restoration)
  • shafi
    shafi Apr 23, 2010
    To check Detection of Device(Power it Down/Disconnect it from Power>Wait 30Seconds>Connect it Again)...Try to format....
    Check Data Cable>Check Partition&Format Status Using device management(Partition&Format are Correct for your Operating System) >Check Drive's Status Using Device Management(driver has Driver Letter Designation).....
    Still problem exist Device need to be manual repair.....
  • 1,555 Answers
Your xp can't read it. either use other OS or vista. You can format it using vista and win 98 will be perfect to read and backup. only exclude xp out of your maxtor.
  • Aruna Singh
    Aruna Singh Apr 23, 2010
    Your disc at present is handling a virus which is corrupting autorun. the best advise from me is kindly plug your hdd to a linux system use mount command alongwith mkfse command to format the disk. After doing this your ehdd will be fine.
Could Maxtor be broken?
Load this utility iSkysoft Data Recover, could help!
Sep 08, 2014 | Seagate Maxtor 750GB One Touch 4 Plus...
I have a Maxtor one touch III 750. When I connect the drive to my PC and turn on the HD, it makes clicking and beeping sounds and wont connect or start up. Is there any way to retrieve that data from the...
Any Un-usual noise from the Disk is not a good sign. you can try the following
1. Try the device on another Computer.
2. Remove the Disk & try on Another Enclosure )Get some help if needed)
May 08, 2010 | Maxtor 1.5TB 7200RPM 16MB USB...
I need the software to get into my Maxtor one touch 4 plus
all of the documentation and downloads for this product are now available via Seagate, as Maxtor was acquired. They are still supporting all the drives Maxtor produced for the normal periods of time.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
Hope this helps FixYa,
Chris
Mar 22, 2010 | Seagate Maxtor 750GB One Touch 4 Plus...
My C:\1386 has error 8211 on my external Maxtor 4 One Touch hardi
1st do restart ...and 2 try to do format ?? or wait me and i will share a programe it will fix ur problem
Mar 13, 2010 | Maxtor Hard Drive
Cant format 400gb usb flash drive
So the disk is recognized? And there is a valid partition on the disk?
What is the error you are getting?
Have a look at this external hard disk troubleshooting, maybe it helps you along.
Jules
Apr 21, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
Maxtor One Touch III
Download and run maxtor powermax, when you run the program it will idenify your hard drives, select your one touch and run the recertify, this will not erase anything but will run a complete diagnostic and attempt recovery of data to recertify as good. If the drive fails I have recovery software I can e-mail you.
Mar 14, 2008 | Computers & Internet
Driver problem
corrupt directory.
if you can read the data, remove it.
then reformat the drive.
if this is not possible, replace the drive.
sorry if the fix does not work.
mark
Dec 21, 2007 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
