Question about Nokia 3110 Cellular Phone
I m using nokia 3110c it automatically switch off and now wen i tried to on it. it starts blinking 2 to 3 times and then switch off again. please help me out to solve the problem
Remove ur sim, battery and mc... let it refresh and again put battery and sim alone... Press green button(call button) ,* and 3 simultaneously and switch on the mobile... make sure that while doing this the "Battery should be in charging"... later, format the memory card and use it... hope this works out well!! And maintain ur phone memory between 250-300 kb.... Al the best!!
Posted on Aug 16, 2010
Hey dnt worry... i had the same problem!... finally found a solution that works!
jst remove your battry for few hrs (8-10 or more) & dan again insert it n it works! worked for me n a few more ppl... All d best! i m using nokia 3110c it automatically switch off - 16x16_smiley-happy.gif
Posted on May 17, 2010
I took the memory card out
and switched on
it worked fine
but dont know y it dont work with memory card :(
Posted on Aug 11, 2010
My nokia 3110c got switched off. then when i
Nokia 3110c while charging the battery& while taking its got switched off.
Jul 26, 2010 | Nokia 3110 Cellular Phone
Restart my 3110c nokia phone how to format my phone with install any software
my nokia 3110 is not starting upp.whenever i try to switch on the phone a light blinks 3-4 times and than again it switch off.. so what should i do
Feb 19, 2010 | Nokia 3110 Cellular Phone
My 3110c phone wont switch on
nookia mobile not switch 3110 on please
helf me
Oct 09, 2009 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
My nokia 3110c is not switching on.what should i do?
My nokia 3110c is not switching on. while switching on its blinking for 3 times and with white flashes and not working.what i have to do?
can i update my cell without going to switching on?
please give the quick solution please
Jul 13, 2009 | Nokia 3110 Cellular Phone
When i restoered the factory settings of my nokia 3110c it only blinks thrice and goes off auomatically. when im trying to switch it off again, it just blinks thrice and goes off automatically , now i cant...
try this: Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck
rate if useful please !
Jun 11, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
419 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
