Question about Canon Pixma MP500 All-In-One InkJet Printer
Error code 5100
I have unplugged it and plugged it in i still get the same code. It will not let me do anything elese. also when i turn it on it makes a awful noise.
  • 148 Answers
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Posted on Mar 23, 2008
    Sergeant:
  • 260 Answers
Http://community.usa.canon.com/t5/Printer-Multifunction-Support/what-is-error-5100-for-multifunction-printeers-and-how-do-you/td-p/6131
Usually an error 5100 code is saying that the ink carriage has problems. Usually something currently is or recently hammed the cartridge carriage. With the machine turned off and the power cord unplugged, open the machine and inspect the inside do you see any stray pieces of paper along the paper's usually route?
for more other help visit https://cbrtechsolutions.net
Posted on Sep 21, 2015
Error code 5100 /this error is an error within the printer. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. Check VERY thoroughly.
How to correct error 5100 on a cannon pixma MP 530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it. Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a Qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges. Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there. Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Aug 19, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Aspire 5100 laptop turnes off after a bit then i turn it on it works fine again after a bit it will do it again it dosn't seem to be getting hot
Possibly a virus issue or hardware starting to go bad. Do you receive any error codes or anything?Anything happen before it shuts down?
Apr 11, 2011 | Acer Aspire 5100 Notebook
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Error code 5100 displayed with orange alarm and green on off buttons flashing on and off
According to the manual, Error message 5100 indicates: "Movement of the FINE Cartridge Holder is blocked. Open the printer
and make sure there is no little piece of paper or other
object keeping it from moving. Unplug the printer.Then disconnect the printer f
from the computer. Plug it back in and try it again.
Aug 11, 2010 | Canon Office Equipment & Supplies
Error code 5100- this keeps coming up when i turn on the printer and will not allow me do anything. Have tried plugging out and back in again, as per manual, but to no avail.
You may need to follow this support documentation from Canon: (please follow along to "Search" for your solution)
In the following page, type the question "error code 5100" and click the <Search> button.
Selphy DS810 Support and Service
Dec 20, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
When I start my canon pixma MX 700 series I gets error code 5100
First of all, make sure you pay attention to when your warranty expires, because this error tends to repeat and you get disgusted and request warranty support only too late. The problem is probably caused by a sticky paper sensor, but the printer must be turned off and turned back on to reset. If it persists in displaying the error, then you should lift open the main part (scanner) look carefully in the back right for the black plastic piece that is the paper sensor and poke it with a narrow scissors or something to nudge it back down. Then turn it back on and hopefully it clears the error. However, if that's the problem then it will likely recur.
Mar 14, 2009 | Canon MX700 Office All-In-One InkJet...
Error 5100 for canon mp530
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Aug 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP510 Error code 5100
Ink cartrige is in the wrong slot and now oth are stuck!!! what do i do????
Mar 31, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
2,036 people viewed this question
old marine
old marine
