Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
How do i use my bissell 7920 - Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
  • 20 Answers
The 7920 is a great little carpet shampooing vacuum. Look up manual information for detailed assembly and starting/breakdown procedures. Make certain that the carpet/floor has been vacuumed previous to cleaning with the shampooer! The small nozzle opening will get clogged with as little as a toothpick or cheerio! Step on the rear release arm pedal and drop the handle down to the floor, Pull up on the resevoir bucket handle and place the handle of the resevoir back down to open the top of the tank and fill the bladder with hot water. Replace bucket top and place bucket back into vacuum. Raise the handle until it clicks into place. Fill on board soap/shampoo dispenser by lifting out of chamber on unit and fill with appropriate Bissell or upright shanpoo cleaner. Replace unit and make certain the top is tight. Plug unit in and turn on both vaccuum switch and preheat water switch and wait approx. 2 minutes to get water hot enough to proceed with cleaning. Start by rollling cleaner onto carpet and engage trigger approx 2-3' pathway away from you and then release trigger and draw vacuum /shamppoooer back over wetted area, repeat without using water again unless heavier traffic area. Do not over wet area draw unit back and forth a few times until water runs clear thru the front clear window. Proceed to make another path along side cleaned area and so on.
Once you hear the water run out or you have finished cleaning an area then shut of heater and vacuum. release handle with foot pedal release and lift out bucket and pour out dirty water and rinse area/tank /resevoir etc. You should also clean the small red filter in the resevoir of any debris by popping out and replacing. Also, there is an onboard filter under the clear window (where spinner is located) . unscrew clear top , take out spinner device and pull out small plastic screen and rinse or blowout. Clean also the front clear cover if there is debris, by rinsing off with sprayer or wiping clean. You may also find that you have to take off the clear plastic hood window, by unscrewing two screws on either side of nozzle opening (top ) and rinse out as well. Do not, get water under unit into motor area. Place unit upright and in a warm place.. Do not let freeze if in climate that is known to freeze. Good luck cleaning!!
Posted on Apr 30, 2010
Bissell 7920. Took it apart how do i align the solution valve
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggds
Nov 23, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Change belt on 7920
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Need a user manual for a bissell proheat pro-tech 7920
Go to bissell.com type in the model number 7920 then go to user guide and you can print it.
Jan 02, 2009 | Bissell 9200 Upright Vacuum
NEED TUBE DIAGRAM FOR PROHEAT 7920
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
7920 ebissell instructions
You can try bissel.com, or the part number for a user manual is 2105811, you may be able to order it, if it is available still.
Sep 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat 7920 replacement pump
Part number is 2107181, it will cost around $30. Most local shops shoul have this part or can order it for you. You could try bissell.com.
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Change the belt on the brush
Dear Norrfam87,here is a website with the manual for your Bissell 7920.
http://www.bissell.com/images/UserGuides/7920.pdf
On page 18 and 19,they tell how to replace the belt !
I hope this helps,EarlsOK
Dec 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
130 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
