Question about Maytag Atlantis MAV6451 Top Load Washer
Wont spin out all the water
The belts are not tight ; how do I SOLVE this
  • 1 more comment
  • rsbabyus Jan 12, 2009
    roper= heavy duty 5 cycle 2 speed
  • Shellmama1 Jan 18, 2009
    I am having the same problem with my Maytag Atlantis MAV7504.
    The clothes are still pretty wet at the end of the spin cycle and water
    is dripping from the top in the back making the clothes wetter before I can get them all out.
  • Kevin Clark Jan 20, 2009
    Clothes are still too wet after last spin on my Maytag Atlantis (MAV8600). Spinning clothes again will take out an additional 2-7 cups of water.
  • 185 Answers
Try putting on a new belt is the drain hose kinked or clogged
Posted on Mar 28, 2008
SOURCE:
BISSELL PROHEAT 2X ADVANCED BRUSHES WONT SPIN
Sounds like you might have got the wrong belt, it should be snug but not super tight. Take belt off and see if the motor spins freely, if so I would try another belt.
Oct 11, 2018 | Bissell Vacuums
Top load Kitchenaid washer KAWS850LQ wont spin. Took off back, found broke belt. Best way to replace belt
It won't spin without the belt. You need to place the belt from the motor to gearbox and there may be a tension pulley. Most are adjusted by loosening the motor and pulling it tight
Dec 02, 2014 | KitchenAid Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
Washer wont spin
The safety latch could be worn or stuck, the lid not closing tight enough to disenage the safety lever
Apr 20, 2013 | Washing Machines
My belt is making a whistling screeching noise. i used belt conditioner and soap both makes it go away as soon as applied but it keeps coming back.
If you have changed the belt I would take it off to see if any of the bearings in a pulley may be going out.You can do this by spinning the pulleys on everything. Spin the water pump,the alt,air compressor. See if they make noise or feel rough while spinning them by hand. Replace whats bad.
Oct 13, 2010 | 1989 Ford F 150
How do I tell if the timing belt is bad. I have the covers off. The crank timing mark is at TDC. the cam marks are also aligned When I first got the covers off the timing belt seemed loose and I could...
Timing belts are supposed to be replaced in intervals, on this vehicle every 60,000 miles. The timing belt may look good, but they mostly stretch over time. As for the looseness and becoming tight, its because there is different compression tension that pull either way. But to be loose to the point you can spin the tensioner pulley, replace everything (belt, tensioner, idler pulley, water pump)!!
Sep 27, 2010 | 1998 Mitsubishi Montero Sport
My washing machine wont spin and is full of water. There is an odor of burning rubber. Is this a belt problem? How can I get the water to drain out in order to repair it?
you have the presostat burned and the electronics, that way the pump is not geting comand to evacuate. you must call a repairman to solve the problem, you can electrocute if you suply whit power the machine.
Feb 21, 2010 | Washing Machines
Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Oct 05, 2007 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
