Question about Miele 3.80 cu. ft. / 108 liter Upright Freezer F311I-6
The thermostat has risen to 30 degrees although we
The thermostat has risen to 30 degrees and remained there it usually stays at 18 although we have defrosted the freezer
  • Miele Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerthe thermostat has risen to 30 degrees although we - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 01, 2010
What should be my pressure on a Delfield 404A refrigerator
As a general rule of thumb, pressure on low side should equal a temperature of about 17-18 degrees if the box is not hot and a high side of ambient plus 30. Again, this is a general rule of thumb that usually gets you close enough to get a unit working providing all other things are right.
May 20, 2014 | Continental Manufacturing Company...
Kenmore elite upright freezer model 25326093100
It does sound like the thermostat is acting up. It could also be a defrost timer if it is a frost free model. The timer could be running slow and remaining in defrost longer than it is designed to. Thermostat can get erretic also and work fine sometimes nad then not work correctly another. When it is shut off after cycling off tap the thermostat. if it comes back on thgis could be your problem.
Apr 03, 2014 | Freezers
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
What should my temperature be in my freezer?
It should be -18 degree Centigrade to ensure food remains frozen and safe for eating.
Dec 14, 2010 | Woods Freezers
Freezer only 33 degrees
The inside temperature should be -18 deg if it is -33 I would suspect it is running constantly, this indicates a faulty thermostat
Nov 29, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer thermostat was set at 0 degrees unit went down to -30 degrees. I increased temp on thermostat 3 degrees 3 times each over a 3 day period. The thermostat is not responding. I have the thermostat set...
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Aug 02, 2010 | Nor-Lake KLF7766C Commercial Freezer
Freezer won't get below 13 degrees
Make sure the evaporator coils behind the rear cover inside the freezer are not iced up too much. This would indicate a defrost problem and will get worse.
If the compressor is still cycling off and on the cold control could be at fault.
Aug 20, 2009 | Freezers
Temperature has dropped from a normal 18 degrees
The only thing that will make it cool to low is a thermostat. They wear out and get out of calibration. Check to be sure the temp sensor from the thermostat is tight on the mount. Its the little tube that connects to the evaporator that makes the thermostat work.
Jul 01, 2009 | AEG Freezers
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Miele 3.80 cu. ft. / 108 liter Upright Freezer F311I-6 Logo
105 people viewed this question
Top Miele Freezers Experts
John Tripp
John Tripp
Jay Finke
Jay Finke
ray gallant
Are you a Miele Freezer Expert? Answer questions, earn points and help others
