Question about Belkin (F5D5231-4) Router
No wireless signal
When I try to go online with my router it says "local only," but I can connect to the internet wired through the router.
sandrew
  • 2961 Answers
SOURCE: Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Posted on Mar 07, 2007
SOURCE: Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Posted on Oct 11, 2008
ubelong2matt
  • 67 Answers
SOURCE: How to fix intermittent wireless signal with Dell Inspiron 1501
It's the Wireless Zero Configuration service that's doing it. Every 10 minutes or so, the WZC service goes out and tries to look for wireless networks. During this time, it can sometimes disconnect from your wireless network. Usually its brief, merely a few seconds, but long enough to kick you out of games, messaging clients, etc.
There is no easy way to resolve this other than stopping the WZC service after startup and successful connection to your wireless. Unfortunately, if you disable this service altogether, your computer will never connect to any wireless and when looking at the Wireless networks list, it'll mention the WZC service is disabled.
You will also need to re-enable this service everytime you take your PC to places where you'll be connecting to other wireless networks. To stop this service, follow these steps:
  1. Go to Start -> Run -> and type "services.msc" (without quotes)
  2. Scroll to the very bottom of the list
  3. Right click on the Wireless Zero Configuration and choose stop
Once it stops, continue working with your wireless network. If you no longer have disconnection problems every 10 minutes roughly, you've solved your problem. Repeat the above steps after every reboot as the service will be re-enabled after the computer restarts.
Posted on Mar 05, 2009
Geekman
  • 32281 Answers
SOURCE: Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Posted on Nov 12, 2009
govinda123
  • 2260 Answers
SOURCE: My router is suddenly not working. The internet,
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Posted on Dec 20, 2009
Hp pavilion dv5
Have you reset the modem first then the router, after doing this restart computer. If you still can't get online: I would first bypass your router or hard wire (Plug Ethernet cable into router or modem) To make sure your computer is able to surf the internet. If you are able to get online, then i would go to Network & Sharing center and on the left side click on (Vista) "Manage Network Connections" and on (7 & 8) click on "Change adapter setting" - Left click on 'Wireless Network Connection' first click on diagnose and see if Windows can fix the issue. If it fixes the isse then your good to go. If it does not then Left click on 'Wireless Network Connection' and go to 'properties' - Check to make sure there is Check mark on -Internet Protocol Version 4 (Tcp/Ip4)- Highlight this (TCP/IP4) and click on Properties. You should have a dot on the Obtain an IP address automatically and Obtain DNS Server address automatically. Try this first and if does not work let me know please put in what Windows your using and what browser and message your getting? And if you can get online by local area connection which is Ethernet hard wired connection?
May 05, 2013 | Computers & Internet
Very slow connection speed
Basically the Wireless Internet always slow compared to wired ,also You can use the instructions in user manual,or get that from Online and then connect to Laptop,check any signal problem in wireless router ,better call the ISP to connect it,they will assist you,You can check the speed of the internet at here Scanmyspeed.com it will show Good Speed.
Jan 16, 2012 | Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Recently my D-link has lost its connectivity, oddly my Mac computer can pick up a wireless signal and access internet while any other wireless devices fail to acquire internet. I tried a cable connection...
Hello, Looks like your Mac might have connected to some other unsecured wireless network in your neighborhood. First connect any computer directly to your modem and check if you are able to go online. If the "internet" light is not lit on the router then there is no way your Mac can access internet through the wireless signals of that router. If you do not have internet connection through your modem then contact your internet service provider. If you are able to go online through your modem then perform the following steps..
1) Disconnect the power from both modem and router wait for a minute and connect the power back for modem first and after ten seconds connect the power for your router. Now once all the lights are stable check if you are able to go online through the router. 2) If the above step didn't work then you will have to reset and reconfigure your router. You will see a small reset button at the back of the router, press and hold it for 10 seconds and let go of it( while power is connected to the router) now disconnect the power from your router and connect it back after 10 seconds. Once you have done this you can reconfigure using the disk provided with the router by re-entering the ISP information. 3) Once this is done check if you have any firmware update to your router by logging on to the router vendor's website and entering your product details.
Hope this helped..!
Mar 09, 2011 | D-Link DIR-655 Wireless Router
My ps3 takes 40 seconds to show friends on list then another 40 toopen text message very frustrating please help me
Unfortunately this has more to do with your internet connection then your PS3 hardware. There are two things you can try with very little investment in time and money. First, make sure your connection is good. If your using a wireless signal, be sure your PS3 is getting plenty of signal. If not, try moving it closer to your wireless router. If your using a wired connection, make sure all wires are plugged in correctly and securely, both into the PS3 and the router.
If your using a wireless connection, try switching to a wired connection. This can improve online features by a significant amount. A good Ethernet cord ( the type used by a PS3 to connect to a router) can be picked up at a good price at your local electronics store, or at a larger hardware store like Home Depot or Lowes. Ask at the help desk and they can point you to the cords.
Mar 06, 2011 | Video Game Consoles & Games
I can log on to my wireless account and get online, but then it i lose the signal, and when i scan, it picks up signal stenght on 90 % but wont connect, I can hard wire it and i get online with no...
The problem lies in the wireless connection. Either the wireless adapter on the game console, or with your wireless router. Although wireless internet makes it easier to get online and play, it is actually the worst choice for online gaming. this is due to the lag time in the signal relay to the router. Wired internet is the best choice for online gaming. If you can hook your console up to a wired internet connection, then I suggest you do that.
Jan 18, 2011 | Video Game Consoles & Games
Hello-just got a ps3 320gb for my son's Christmas present. We're having trouble connecting to the internet--we have no issues doing so wirelessly w/ 3 other computers in the house. the console can find the...
try using a wired connection. most wireless are pretty bad connections for online mode. when you use it, go(on the ps3) on SETTINGS then INTERNET CONNECTION SETTINGS then try wired, or wireless and try again. =)
Dec 28, 2010 | Video Game Consoles & Games
No internet access
  • power cycle the modem and router
  • bypassed router
  • called the router provider for router configuration
  • use window zero configuration
  • makes sure you are with strong signal and within 50 meters raiduis of router.
May 03, 2009 | Computers & Internet
I'm trying to connect my DSi to my home network through my router
if your computer can do the internet, the only thing i can suggest as i have limited knowledge is that you get a Nintendo LAN adapter which you plug into your computer when its online and it sends the WiFi signal to the DSi
Apr 11, 2009 | Nintendo DSi Black Console
Wireless G and Comcast cable internet
Im not sure about the monopoly thing?
But it must the settings that is causing a problem.
If I understand you concern correctly your computer is connecting to the router wirelessly, is that right?
and can you get online if the computer is wired directly to the router?
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Belkin (F5D5231-4) Router Logo
65 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
