Wahl 5000 Custom Shave System Electric Shaver Logo
Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the part for a Wahl shaver that the cutter bar attaches to. It's a white, flexible plastic thing. Where can I buy it?
shaveroutlet.com
Level 3:
  • Wahl Master 1,652 Answers
  • Posted on Apr 23, 2010
shaveroutlet.com
Wahl Master
Level 3:
Answers
1652
Questions
0
Helped
765659
Points
4209
Brought a new cutting bar but would not cut
Most, likely, your oscillator is broken. It is the plastic piece that transfers the rotary motion of the motor to a 'back and forth' motion
Wahl DynaFlex ID Shaver Oscillator
How do I disassemble a wahl 4000 shaver
Remove the foil and cutter as usual. Then remove the two metal clips on the top of the shaver body. The front and back cases can now be separated at the top and will come apart
Dissasemble to change battey
Remove the foil and cutter. Under the cutter are two metal clips. Remove clips and you will then be able to seperate the two halves.
You will find a new battery for model 7367 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-for-older-norelcoremingtonronsonwindmerewahl-p-212.html
7helpful
2answers
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 • Wahl 8550
1helpful
Where can I buy attachments for Wahl Super Taper Hair trimmer. Full kit or just No 3?
Manny's Sharpening has the Wahl attachment for $3.00 ea any size from 1/2" to No 9 323 263-4697
1helpful
Wahl KM-SS pet shaver motor runs but cutters dont move
it seem that shunt arm that move the cutter blade is broken or off it's guide without look at it it's hard to tell what wrong, try Contact [email protected] they are a Wahl Dealer they have all the parts for Wahl clippers. they can help.
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
