Question about Lexmark X4550 InkJet Printer
Printer has stopped scanning, error message cannot download application data
Mine does this too.
When the error comes up press the red X cancel button then select the computer name again and press the tick button it should then find the application list ok.
Posted on May 12, 2010
Searching for scanning applications error?
Are you wanting to scan? Click on the help toolbar and type in what you are looking for.
Aug 11, 2014 | Lexmark X1270 All-In-One InkJet Printer
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
After scan, whatever save function is used the error message "printing application has stopped working" appears with the only option Close Application.
Try to re-install the Lexmark X4650 driver. Visit the Lexmark website at http://bit.ly/iofMNC. Select your operating system, download the driver and execute the file.
Jun 18, 2011 | Lexmark X4650 InkJet Printer
Impact s305 printer won't scan. it's stuck on "downloading application list"
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Mar 11, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Searching for Scanning Applications error message
Have you plugged the printer into the PC? Sorry to have to ask this but it is amazing how many people don't realise that this is required (USB lead usually). I don't know how old the printer is but your problem may be because the printer software is not compatible with the new computer (I.e. software for XP and you have Vista, or something like that).
Dec 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
I am unable to scan. While in the Scan Mode, the message says "Downloading scan application list from your computer, please wait" The next message says "cannot retrieve scan application list from my...
the reason why the printer is giving you that error msg is because the all in one center is not communicating properly with the programs on your computer to your printer.
try to scan directly to your computer using the all in one center instead.
Jul 23, 2009 | Dell 966 All-In-One InkJet Printer
Scanner problem
Hi s2009edwards, double check the USB data cable from the printer to the computer. Power off the printer. Than, unplug the data cable connected to the printer & re-connect it. Follow the data cable to the PC & unplug the cable & re-connect it. Power on the printer & wait until its done making noise. Try scanning again. If it fails to complete & you receive the same error message than buy a new printer data USB cable & replace the old one.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=76&SRCCODE=WEBGOOCOMP&cm_mmc_o=7BBTkwCjC-p8ByplCjCabTwyKbywgfCjCmH4
If the HP director software is installed (Which it should be).
You can open HP printer software there should be an HP icon down by the clock. Right click on it once & left click open or launch. If you did not install your HP printer software suggest you do so.
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Win32 application
Backup data and reinstall XP or
Get free AV best out there - http://www.avast.com
Try to install in safe mode if possible. Download from the net in normal mode, go into safe mode and install, tell it to perform full scan. If you can't install, your OS seems too bad to fix. Backup data!
G'luck
Oct 24, 2008 | Microsoft Windows XP Home Edition
Error 6000
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Nov 13, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Lexmark X4550 InkJet Printer Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
