Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
REFRIDGE KEEPS CLICKING BUT DOESN'T GET COLD NO MORE JUST KEEPS CLICKING AND THE COMPRESSSOR GOES ON AND OFF WITH THE CLICKING
  • 27 Answers
If you are hearing a click every so often coming from the back of the ref and it's not cooling you have a bad start device
Posted on Apr 23, 2010
Refridgerator does not get cold and emits a clicking sounddown by the motor.
It may be the thermal overload protector clicking due to a locked rotor in the compressor. A bad start capacitor can cause this too.
Jan 10, 2015 | Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works, refridge works gets cold but sometimes power goes out on refridge side and then tries to cycle on. if i unplug unit from wall and reboot then it will work is there a sensor for too low...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridge runs but does not cool and freezer is cool but doesn't freeze
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Refrigerators
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
Fridge compartment is not cold enough
inside the back of your freezer there are two holes that lead to your refrige there is also a fan with a small motor attached is the fan blowing the air fromthe freezer into the refridge section also are the two holes plugged up with ice these are some of the first things that you should be checking turning that switch basicly jut opens the damper door that goes fromthe freezer to the fridge so in allactuality if the door is pluged with ice or the air isnt being pushed through those holes your refridge wont get that cold also another thing to check would be the operation of that small damper door if you do have a fan runnning and do not have ice but if the door is always closed this could also cause this problem hope this helps
Jul 16, 2010 | Hoover HDA452 Top Freezer Refrigerator
Refridgator too cold and on highest setting
i'm guessing your fridge is over - packed with alot of food - i found if i made more space - temperature returned to normal cooling.
hope this helps
marneypants
Oct 02, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
