Question about Cisco Agent Desktop For IPCC (IPC-AGTCAD-L)
Cisco Desktop agent state automatically goes to NOT Ready state
Where is nearest distributor for Oster Automatic Overblanket near Melbourne Victoria
go on line and type in distributors for Oster automatic over blanket and it will show where agents and distributors are for the state including the capital
if not it will show who the importers are so that you can contact them
May 22, 2015 | Cars & Trucks
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
Mar 01, 2013 | Belkin Surf N300 Wireless N Router
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
SecureCRT - Version 6.2.2 (build 263) [LOCAL] : SSH2Core version 6.2.0.263 [LOCAL] : Connecting to 10.252.105.6:22 ... [LOCAL] : Changing state from STATE_NOT_CONNECTED to STATE_EXPECT_KEX_INIT...
This log shows you are connecting to a Cisco router running SSH protocol version 1, but you have set your SecureCRT to require using SSH version 2.
You either need to either
Set the SecureCRT software to allow connections using SSH version 1
or
upgrade your Cisco device to support SSH version 2.
Apr 15, 2011 | Van Dyke Technologies SecureCRT With...
Trying to connect with Cisco. VPN is connected then get error message of Clean Access Server is not available.
sniblett88:
This is most likely either a problem with the software running on your computer or the Cisco Clean Access Server is currently unavailable.
Some things that you can try with the Clean Access software to get it to start responding again include:
  1. Right-mouse clicking on the Cisco NAC agent icon in the tray (lower right-hand corner of the screen) and make sure that "Popup Login Window" is selected with a checkmark
  2. Right-mouse clicking on the Cisco NAC agent icon in the tray, and select Properties and check that the "Discovery Host" entry is filled in and not corrupted. If it is missing or corrupted, then you will need to contact your company's helpdesk for the host information.
If both of the above items seem to be in order, then most likely the host on your company network is unavailable. Call your company's helpdesk in order to determine if this is the case.
Thanks for using FixYa
Jan 15, 2011 | Cisco Clean Access Server
Problem with my supervisor Desktop
chat has to be enabled in order for the cisco agent to communicate properly. if the firewall is blocking the chat then the agent will disappear from the queue but the agent will still be able to receive calls.
Aug 11, 2009 | Cisco Supervisor Desktop For IPCC...
Computers & Internet Logo
137 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
