Here this step by step to resetting waste ink counter Pixma MP130. However remember that this can cause damage to your printer unless the ink absorber pads are replaced. The reason the printer has this is to keep the pads from becoming too full and then dumping the ink inside the printer. So i highly recommend to order the pads replace them then reset the counter. However if you are in a 911 situation then you can use the following to print a few more pages before you have to replace. Just BE WARNED.
Turn printer back on and it should be reset. Good luck sometimes this does not work on certain printers with higher firmware so try thanks
Steven.
SOURCE: How to fix "Ink Absorber Full"??
The ink absorber is a small piece of material that is used to hold the ink that is scraped from print heads on the ink tanks during cleaning. I suggest, wearing gloves of course, removing the material, which resembles a sponge, and cleaning it with warm water. Allow sufficient time to dry, clean the sensor with a cotton swab, and reinstall. Remember to change the ink tanks at the same time, in order to reset the ink counter. There are new absorbers available for purchase on the web, if you don't want to clean the old one. Others have had similar problems, Canon suggests sending the equipment to them for repair.
SOURCE: Canon PIXMA iP 1000: Waste ink abeorber is full
1. Disconnect printer power cord
2. Open the printer cover
3. Press and holding power button connect power cord
4. Close cover and release power button (you are now in service mode)
5. Download and use to reset this tool
http://www.servicemanuals.ru/download/canon/ip1000st.zip
6. Unzip and remove read-only attributes from files Pattern.prn and EEPROMData.prn
7. If it did not recognize the printer on usb port - you must enter the port mannually (ex. USB017), info taken on printer properties.
8. VOTE as FixYa!!!!!!
SOURCE: Waste ink absorber on canon iP 1600
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
SOURCE: Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
