Question about Canon imageRUNNER 3300 All-In-One Laser Printer
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
  • 1,219 Answers
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Posted on Apr 26, 2010
    New Friend:
Hello sir,
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
Posted on Feb 05, 2014
Error 0590 (p 1) TheLegal paper jammed Legal repented and none paper jamm foun
Posted on Jan 15, 2012
How to fix the erroe code e0004 in ir canon 6000
press setting/function button then 2&8 same time with two fingers then gain press setting
screen will change to service mode
select mode-copier-function-clear-ok restart machine.
Oct 21, 2016 | Canon Office Equipment & Supplies
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Jun 27, 2012 | Canon Service Manual For Ir 6000
When i put my canon IR 2318 on, the code E000010-0000 appears; what can I do to move it?
this is error code for main motor failure, you can try to reconnect main motor, look for breakege of gears, reconnect dc controller, or the main motor must be replaced or dc controller, or ...
As you can see that there is a lot of things that can be fault, so call service!!!
Aug 28, 2011 | Canon imageRUNNER 6000 Copier
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
IR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Jan 21, 2009 | Canon iR5000-6000-L1 PS Ver 1.0
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
2,403 people viewed this question
old marine
old marine
