I have a bose sounddock which when the aux cable is plugged in causes a buzzing sound which will not go away until I tense the wire to one particular side. I suspect that the metal connector inside the dock is twisted and not making full contact with the metal part of the aux cable. How do I fix it DIY?
    Champion:
  • 287 Answers
The jack has most likely cracked a foil on the board it's mounted on . Get your solder iron scrape and solder and splice if needed it back on the board. Pretty easy one here. email me for more questions. Larry's Electronics ledstiles@hotmail.com
Posted on Apr 24, 2010
Bose SoundDock got wet
No! the Bose unit would need to be serviced by them, there are no authorized technicians outside of the factory, plus they have the needed parts.
Apr 08, 2012 | Bose SoundDock Portable Digital Music...
I have no radio siegnel from my ipod nano in my bose sound dock
The ipod headphone cord acts as an antenna, and with the design of the nano you can't plug them into the ipod and the docking station at the same time. You can buy an audio adapter cable - a 3.5mm to 3.5mm one; just plug one end into your ipod and the other end into the aux port on the back of your dock. You can then use the radio, as the cable will act as the antenna. I got one on ebay - the cable has plugs on each end which are the same size as your ipod headphone plug. You can also get them in variety stores or electrical stores.
Sep 20, 2010 | Bose SoundDock digital music system...
Right channel of Bose sounddock out completely. Does not seem like a blowout-- just not working. Can I fix it myself, or do I need to send it to Bose to be fixed? Please help!
Try another Ipod first.Go to Bose website for tech help if this is not the solution.Is the Ipod connector damage on the bose or your Ipod?
Oct 18, 2009 | Bose SoundDock Digital Music System for...
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Bose ipod speakers not working just no sound it is powering up
Try the fallowing
First things first, unplug the SoundDock. Plug it back in and try again. Then take the Dock insert out....and try it again. If that doesnt work check the power cable. A common problem is that people plug it in the wrong way into the Bose SoundDock. If that still doesnt fix your problem. Bring the product to your nearest bose store if its still in warranty. If not, call 1(800)644-2673.
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Audio Players & Recorders
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
60 people viewed this question
 Grubhead
Grubhead
