Question about Ryobi Cultivator
Is the top or bottom line the return fuel line
Is the top or bottom line on the carb the return fuel line
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
#1 Taper
  • 1040 Answers
SOURCE: location of fuel lines, where they terminate.
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Just let me know if you need further assistance.
Jim
Posted on Jun 24, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
panilling9
  • 284 Answers
SOURCE: Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
Posted on May 09, 2010
Testimonial: "Thank you"
rycgl
  • 1545 Answers
SOURCE: Does the fuel return line go from the bottom of
The return line goes from the side of the carb that has the cover with the vent hole (metering chamber) back to the primer bulb (if primer bulb is external) and thru the bulb and THEN back to the carb. If the bulb is on top of the carb, then the fuel return is in fact coming from the "bottom" (metering chamber) side of the carburetor and to the fuel tank.
Posted on Jan 05, 2011
Where the fuel lines go on a mcculloch 2.0 2014 chainsaw
The return line needs to inserted only about an inch into the tank as it is only returning fuel and not picking up fuel. Note some these return lines on other models have a line coupler on the end to prevent from coming back out.
Feb 02, 2015 | McCulloch Garden
I have a craftsman 358.797931 w/ a walbro carb with primer bulb on top.what line takes the fuel filter and which line goes where on carb. Top and lower tubes
The hose with the fuel filter will go to the bottom of the carb, the top hose off the carb will go to the inlet of the primer and the primer outlet will return to the tank
Feb 04, 2013 | Garden
Ryobi mdl RY 26921, the fuel line from the tank - which fitting on the carb does it go on? Top(where the bulb is) or bottom?
The main fuel line from the tank that has the filter in the tank on the end of it will connect to the brass nipple near the bottom of the carb. The top nipple by the bulb is the return line and just sends air/old fuel back into the fuel tank. So, fuel supply line is connected on the OTHER end of the carb.
Sep 02, 2011 | Ryobi Three Trimmer Combo
Does the fuel return line go from the bottom of the carb back into the bottom of the fuel tank
Jan 03, 2011 | Ryobi Garden
Fuel lines
line from the tank with the filter on it goes to the bottom inlet or( depicted inlet) on the carb the top is the return line that goes to the inlet of the primer the other side of primer goes to tank.Primer draws fuel thru carb to tank
If primer is mounted on carb filter line = inlet to bottom fitting= other is return to tank
May 28, 2010 | Garden
Which carb line is intake and which is return?
the line from the primer is the return to tank, which makes the other to the fuel filter...
Apr 17, 2010 | Troy-Bilt Garden
Replaced primer bulb and fuel lines, now it won't stay running
The smaller line is the supply to the carb. and should have the filter in the tank, with sufficient length to allow fuel pickup from the bottom of the tank.The larger line returns excess fuel and pressure to the top of the tank.By squeezing the bulb and watching the fuel lines you will be able to determine if you have them right on the carb.
Sep 27, 2009 | Poulan Featherlite Gas Blower, with Low...
Which lines hook to what?
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Aug 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Trimmer fuel way...
Start from the tank(fuel filter) connect to the filter then to the top of the carb.Top of carb is where the H & L screws of carb is.Then from bottom of carb to primer bulp(**** side)then from primer(blow side)to tank return.
Aug 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Cultivator Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
