Question about Amana ABB1921DE Bottom Freezer Refrigerator
Fridge problem Freezer is freezing properly. Fridge is warm, even when temperature is set to 7.
  • mejill Jun 17, 2008
    I have very little air coming out of the refrig. and wha tis coming out is not is warm. The freezer is working fine. HELP...can't afford to have this problem.
  • Anonymous Mar 24, 2014
    Freezer light says warm temperature
    Scholar:
  • 27 Answers
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Visit me on Ebay username: themackshack. Good luck! Mack
Posted on Mar 23, 2008
SOURCE:
I have a GE Hotpoint fridge Model CTX14CAXKRWH. Freezer is over freezing & main unit warm/wet with condensation. Is this a thermostat issue? Is it even worth replacing in a unit from 1994?
Check the freezer fan motor if one. Also check the doorway that allows freezer air into the refrigerator part for proper operation.
Feb 22, 2017 | GE Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Refridgerator and freezer running warm
Your temperature is probably set to high turn it down to about 4 for a couple hours and then back up like 7 dont turn both controls up all the way or it will freeze up on you. You could even unplug it for an hour and let it thaw out then turn it back on the freezer to 7 and the fridge like halfway or a little more than half.... see if this works for you...........Have a good week end! : )
May 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Fridge problem
hi
is this a frost free fridge if so then it is possibly not defrostingand has built up to much ice in the evaperator
cheers grantsreps
Sep 29, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
Amana ABB1921DE Bottom Freezer Refrigerator Logo
331 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
