Question about Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000
My printer will not print off a self test label
My printer will not print off self test labels
5 Suggested Answers
SOURCE: Cannot print test page from PC on Zebra DA402 label printer
Which driver are you using? Did you try the Seagull drivers?
ftp://ftp.seagullscientific.com/drivers/archive/7.1/7.1.4/Zebra_7.1.4.exe
Posted on Mar 07, 2009
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
  • 10 Answers
SOURCE: Alignment of print with Labels
Sid
Perform a media calibration as follows: -
Turn the printer off
Press and hold the green button and turn on the printer.
When the red flashes 3-4 times release the button and the printer shoould perform a calibration, then try printing again. Any futher problem with this contact Lancer labels
Posted on May 15, 2009
SOURCE: Printer is only printing on every other label.
I had a Zebra 90xill that started printing every other label even after full calibration of media and ribbon. Cleaened sensors to no avail. Set factory reset - No Change
If this occurs it is a sensor problem. I replaced the top sensor - It now works perfectly
Posted on Nov 28, 2010
After I sent a print job to the printer, it prints out the label required but it does not stop feeding the labels. Please advice how to resolve this.
hi,
- Turn off the printer.
- Remove the labels roll and then load it again.
- Press and hold the green[feed] button and switch on the printer.
- Release the button after it flashes red.
- The printer will run a self test.
- Turn it off and then on again.
- Now print.
good luck!
Sep 15, 2011 | Zebra TLP 2844-Z Thermal Label Printer
My label starts printing halfway down the label
hi,
1. Check the printer settings of the software you are printing with.[most
probable cause]
cause]]
2. Turn off printer.
Open the printer and remove the labels roll.Re-load it and close the printer.
Press and hold the feed button.
Power on the printer and release button after first flash of led light.
Printer will self test.
Turn it off and on again.
Now print.
good luck!
Sep 09, 2011 | Zebra Z4Mplus Label Printer
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Zebra 105SL prints 90 degs to what's on the screen
Print out a Cancel Self Test label:
1. Turn the printer off
2. Press and hold the CANCEL button while you turn the printer on.
If the label that prints out looks normal, you have a config issue in either your printer driver or your label software's page setup.
Mar 04, 2010 | Zebra 105SL Thermal Label Printer
Second hand zebra 90 xi doesn't function with my computer. everything works except printing the label
Did you try any of the self test labels? When the printer is turned off, press and hold either the PAUSE or CANCEL front panel buttons while you turn the printer on.
If a label prints out, you likely have communications issues (maybe bad printer cable) or possibly printer driver issues (try to download and install the Seagull driver from www.seagullscientific.com)
Mar 03, 2010 | Zebra 90XI II Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000 Logo
27 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
