Question about Dell Dimension 4600 PC Desktop
Motherboard fails to see Hard Drive...please help
I am trying to get this pc up and running, but the mother board will not recognize the IDE Hard Drive. It doesn't show up in the bios. I have tried all jumper settings. all other drives are seen, (2) optical and (1) floppy. It sees a hard drive conected via usb, but will not let me install an OS on it. I'v also tried switching out the IDE cables, and that does nothing. Also tried other Hard Drives and none of them are seen. Please help.. thanks
    President:
  • 778 Answers
When you say "I'v also tried switching out the IDE cables", did you mean that you changed them from one socket to the other on the MoBo, as in disconnecting the cable with the two optical drives on it completely and connecting the cable with the harddrive on it in to the socket that is recognizing the two optical drives? If not give that a try and see if it's recognized.
Posted on Mar 23, 2008
    Genius:
  • 1,027 Answers
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Unit won't work
I prefer to use my IDE hard drives as either slaves or masters. If you have another drive on the same cable, one needs to be master, the other should be slave. This applies to CD or DVD units on the same cable, too. On the same end of the hard drive as the plug, there will be a small removable plug. On the paper on the hard drive, or maybe stamped on the circuit board, will be M for master and S for slave. Move the jumper as indicated so you have one of each, and be sure you have the IDE and the power plug firmly connected.Usually the IDE plug farthest away from the motherboard end is for the master. It should be marked master and slave, although it may be 0 and 1 or 1 and 2. Once you have this done correctly, if the mother board still does not see it, you will need to go into the bios setup and tell the board you have an IDE drive. This varies wildly from one manufacturer to the next how to do it, be sure to make only one change at a time to the BIOS, and write it down. If what you did does not make the drive show up, put the BIOS back the way it was and try another setting. Write it down. Your motherboard supports SATA, so if this an additional drive for storage or backup, - if your CD or DVD is SATA, the new hard drive should be a master.
Dec 23, 2017 | Genica Computers & Internet
Hi Intel mother board D 845EPI After replacing
-make sure that the hard drive cable (IDE cable) is plugged-in correctly. It is possibly inverted.
Dec 18, 2010 | Intel Desktop Board D845EPI Motherboard
I want to install window XP into DH55TC mother board with eSATA hard drive with 500 GB but os is not support the eSATA drive. Please suggest for the same.
is it the motherboard that will not support the sata hard drive
does it have 40 pin Ide leads
if so you will have to get a Ide to Sata adapter which yuo can buy on Ebay for about $8aus
hope this helps
Dec 11, 2010 | Intel DH55TC Motherboard
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Where can I find a driver for my hitachi travelstar IC25N080ATMR04-0
1. You shouldn't need a driver for the hard drive
the Bios ( Basic Input/output system ).
2. You mother board should detect the driver
3. You will have to go into the BIOS setup to see of your hard drive is detect then set the BIOS to boot from the hard drive
4. If your pc takes SATA ( Serial advance technology attachment) then a IDE ( Intelligent drive electronics) will not work with the system without an adapter.
5. Your PC mother board instruction manual will have instruction on hard to access your BIOS settings
Caution: Any changes in the BIOS will not allow some devices attached to your PC to work properly is not properly addressed in the BIOS setup.
Mar 19, 2010 | Computers & Internet
Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
152 people viewed this question
Alun Cox
