Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
Hi, I've owned a Fender Hot Rod Deluxe since '01. Around '06 I started having problems like crackling sounds when on but guitars volume was all the way down. Loss of volume here and there. While amp was on it would just die and to get it back on I'd have to switch the "Standby" switch on and off hard and then I'd get signal back. I brought down to a tech in the area who gave it a clean bill of health. Two weeks later at a gig it totally died. I took it upon my self to re-tube the amp with the exact OEM tubes. It helped a bit only to have, in 5 months, the same problems happen. My friend gave me another newer HRDeluxe to help me out but that one, when the Reverb knob is at 5 it produces a weird high frequency to the over all signal that only goes away when the Reverb knob is all the way off. If anyone can help with any suggestions I'd greatly appreciate it. Thanks in advance.
  • Fender Master
  • 5,603 Answers
In YOUR amp, take a pencil and tap teh sides of the tubes GENTLY, listening for any crackling... note SOME microphonics is normal in the preamp stages.
Since retubing it fixed it once, it is likely either a tube was bad OR a pin of a tube wasn't quite making so replacing the tubes cleaned it and made it work. Tubes DO go bad, especially when they are vibrated like in these amps... BUT don't just replace the lot, try to find which is at fault..
On your friends unit, LIKELY an electrolytic bypass capacitor for one of the reverb preamp stages has dried out and needs replacing.
Posted on Apr 24, 2010
Testimonial: "Thanks so much. I will take your advice with the pencil. And thanks for mentioning the other HRDeluxe reverb prob. I will have my tech buddy check."
Hot Rod Deluxe
Most likely clipping. This happens when the source DBs are too high for the amp....feeding in too hot.
Jul 17, 2014 | Fender Hot Rod Deluxe Guitar Combo...
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe. Works great except when I turn the amp off it crackles pretty loud. It takes about 5-10 seconds for the crackle is heard. If I turn the standby switch first, then wait a minute or...
As voltages drop, electronics gets unstable as it goes down and becomes noisy... this may be the nature of this beast. Opening the standby might be the best way to avoid the problem.. Here is your schematic for service:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Opening the standby switch turns off power to the main amp so noise generated in the preamp will not be amplified.
Jul 25, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hi, I recently bought a fender hot rod deluxe which gives a very noticeable static sound. On the clean channel with the volume up to 4 it will be very audible. Is this normal or should it be brought to a...
Hello. You might have a "Tube rattle" problem. This is very common in these amps.
google "tube rattle" and you will find alot of people having the same issue.
There is some rubber tube dampers that you can buy to stop the rattling.
Hope this will help
/Daniel
Sep 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Sound comes and goes on the drive channel, and there is a strange crackling on the clean channel. i dont know if its the tubes, the speaker, or electronics.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
Sep 03, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
353 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
