Hi, does my compaq presario notebook v4002ap have an internal infrared port? if so, where do I locate it and how do I set it up? thanks
  • krussell73 Apr 23, 2010
    hi, i wish to use it to connect with my infrared mobile phone. I cannot find anything resembling an infrared port on my computer anywhere. I do have bluetooth wireless adapter though. Is this used as the infrared port?
    hi, i have had a look in the BIOS and there's no infrared port mentioned. The wireless LAN is mentioned but nothing about infrared. So i guess there is no infrared port. thanks
  • 1,555 Answers
Yes Your laptop do have inbuilt infrared. Kindly let me know for what purpose do you wish to use your IR. So that I can guide you properly on setting it up.
Posted on Apr 23, 2010
  • 1 more comment
  • Aruna Singh
    Aruna Singh Apr 23, 2010
    Here is what IR in general. Its just a small led on the output side and line of sight is crucial for connectivity.
    What IR is all about
    What's up with IR, and how do you set it up? What's up is it's a very fast method for two devices to communicate and it doesn't require any cables. You'll also find IR used as the technology behind many remote control devices (stereo, TV, etc.). For computers, IR was a huge improvement over the old serial interface--primarily in terms of raw speed.
    USB came along after IR. Because USB didn't require line of sight, it gained popularity over IR. This, despite the fact IR is typically much faster than USB.
    Bluetooth has since come along, offering the advantages of both--high speed connection and no line of sight requirement.
    But not everybody has Bluetooth (cost is a huge factor), and not all device mfrs have migrated to it. The fear is something else will come along and displace it. IR is still very much alive. The latest Pocket PC (2006, as of this writing) still has an IR port (in addition to USB and Bluetooth).
    Setting up IR
    So, how do you set up IR? It's actually very simple. With Windows 2000 and later, it's pretty much auto-recognize. Here are the major steps:
    On your device (pen, PDA, etc.), go into wherever the connection settings are and select IR. This may be called by other names, the most popular being "beam." Why this name? Because of Star Trek on the one hand, and an old series of Dilbert cartoons on the other. Follow the prompts--usually there is nothing more to do than to check a box.
    On your PC, you will typically need to enable this in the BIOS. Just reboot and enter the BIOS area. For most PCs, that means keep tapping the Delete key. On some, there may be another access method (Dell, for example, uses the F2 key). Windows will automatically configure for the IR to work. You may have to play with the COM port setting a few times in BIOS for IR to work without disabling something else.
    Best advice ever
    Be sure to test everything. Now, here's some advice that you can either follow or learn the hard way. The hard way may include taking your PC to a shop and paying for service.
    Before making a change in the BIOS, write down the item being changed. Note the setting "As Is" and then "As Left."
    When changing the BIOS, change one thing at a time. Never two.
    Test your computer for the intended change. Then, test for unintended changes by trying other I/O devices such as your mouse, keyboard, printer, etc.
    If something doesn't work, your written trail of changes will allow you to back up to a known good state and restore proper operation.
  • Aruna Singh
    I'd like to request you to kindly mention the model number of your mobile. If till now you are unable to locate your IR setup on you system kindly let me know. I need both the models with make and company your system and your mobile.
  • Aruna Singh
    I've checked your laptops specs and they state that your laptop has an inbuilt IR. It might be a rectangular or circular opaque black or red glass just like on CRT television.
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
None of the USB ports on my Compaq Presario R
Hi there!
Have you tried checking your BIOS? Pls make sure that the on board USB setting are enabled...this should fall under the integrated peripherals...
Hope it helps!
Feb 23, 2010 | HP Compaq Presario R4000 Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Drivers installation
To install the drivers you do not need to use device manager.
HP drivers are self installing .
Just download the driver installers from website below and run the files after download has finished.
Compaq Presario C700 Notebook PC series - Download drivers
Feb 18, 2009 | Compaq Presario 700 470024-192 Notebook
Hi i wanted to add a port replicator to my compaq presario b2800 laptop but i dont see how because under the laptop i see nothing where the slot would fit into the port replicator Cheers lyn
http://h10061.www1.hp.com/ccsearch/search?pname=Compaq+Presario+B2800+&opname=Compaq+Presario+B2800+CTO+Notebook+PC&qry=port+replicator&submit.x=0&submit.y=0&method=prodFinder&ctry=sg&lang=en&dlc=en&sni=1144707&search=0
check on this site with your model
Aug 13, 2008 | Computers & Internet
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Skype cant hear me
yes sir,you need to have a microphone, i believe there is a microphone port on you computer..
Jun 24, 2008 | HP Compaq Presario V2000 Notebook
DRIVERS
There are six models of C700. Which one is yours? The models are:
» Compaq Presario C700 CTO Notebook PC
» Compaq Presario C700EM Notebook PC
» Compaq Presario C700ET Notebook PC
» Compaq Presario C700LA Notebook PC
» Compaq Presario C700T CTO Notebook PC
» Compaq Presario C700XX Notebook PC
These links will take you to HP's site at the right location for the model you select. HP now supply the drivers for Compaq, so it's here you need to look.
May 22, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
David Payne
David Payne
