Lighting the pilot light on a Worcester 24CDi combi boiler.
I have a worcester 24CDi combi boiler. The pilot light has gone out and I dont know how to relight! No manual available to offer guidance can you?
  • Anonymous Mar 18, 2014
    overflow pipe always leaking
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Posted on Apr 23, 2010
  • tracy wood Dec 29, 2012
    I have made the pressure higher and it is now between 1 and 2 and It will still not ignite. What do I do now?
Hi, this is Worcester, Bosch Group
You can download manuals from our website www.worcester-bosch.co.uk/homeowner/literature if you need them.
Our technical team can help with enquiries, please call 0844 892 3366
We look forward to helping you.
Posted on Apr 26, 2010
How do I reset pilot light on greenstar28i junior combi
found this on how to reset it hope it helps...
https://forums.digitalspy.com/discussion/2014658/worcester-greenstar-28i-junior-boiler-fault
Mar 01, 2018 | Water Heaters
I have a Worcester 24cdi combi boiler. When I put the hot water tap on, the water comes out cold. The hot water light on the boiler is flashing rapidly and the flame indicator light also flashes red. I...
i would take it back trade it in for a new one depending on how long you've had the boiler for, i ad the same problem with mine, so i brought mine back in they couldn't fine the problem so the gave me a new free of charge, also read the manual for that thing thats one thing i never did when i first got mine
Aug 16, 2013 | Heating & Cooling
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
I have worcester combi boiler 24CDI RSF, the boiler will not ignite, for the hot water or the central heating, it was working ok, and the red water light is flashing
i think the fan may be stuck. you will need to gain access to the internals of the boiler so a gas safe engineer will need to be employed to do it. if it is the fan, a simple squirt of lubricant will free it and give you anything from a week to a year of trouble free operation but! you will need to get a new fan. Fit a new one as soon as you can as they tend to go at the worst possible time if you dont
Oct 20, 2011 | Combi Centre DX - Mango
Worcester 24i boiler..how do i re-ignite the pilot light??
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Apr 27, 2011 | Heating & Cooling
I have a twenty year old worcester combi boiler with pilot light failure. It relights following instructions and is fine for a week or so then problem arises again, only this time it won't relight at all....
If you are lucky it may just be a worn out thermocouple or maybe a choked pilot jet or the gas valve may have gone faulty and require replacement, if you haven't had the boiler serviced on a regular yearly basis then a service will be required and any other worn parts replaced,fans,pressure switch, thermistors and safety stats are all parts that wear out after a few years, your oher option would be to replace your boiler with a new high efficiency boiler without a pilot, cheaper to run and better for the planet.
Mar 01, 2009 | Combi Centre DX - Mango
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
5,827 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
