Question about Acer Computers & Internet
I cant make my tv work as a monitor with vga cable
    Scholar:
  • 78 Answers
Please follow the following link, i am sure his will help you.
http://www.howtodothings.com/electronics/a3543-how-to-use-your-tv-as-a-computer-monitor.html
Posted on Apr 23, 2010
VGA to HDMI converter connection and set up
Use VGA adapter to HDMI works for video
Sound is carried over stereo cable
What you are doing needs 2 cables
Video cable for video
Sound cable for sound
Using TV for monitor VGA to HDMI 32" at 120 refresh is best dot pitch .
over 32" dot pitch is lower may become grainy resolve place monitor away more from you when using over 32" TV 120 refresh is important
Jul 15, 2016 | Computers & Internet
Can i use my tv as a monitor for my home computer (Dell Optiplex 745)and if so how. I tried difrent ways and cant seam to do it.Help. Please. Chris.
The TV should have VGA input socket to connect with. if have; you can connect the TV with the computer, using a VGA to VGA cable.
VGA input socket.
VGA - VGA cable
25737496-zeccwmaoed3oumaueic5tnov-2-2.jpg http://electronicshelponline.blogspot.com/
Jun 09, 2015 | RCA Televison & Video
My laptop is vga,so i have bought a vga cable,and a converter box with HDMI cable. My samsung series 5 tv will not pick up the laptop. i have tried all the options available but it just says check devices...
Wouldn't it be NICE to know what laptop you are referring to
Oh well...........maybe one day
By factory default settings the display should automatically show in the external VGA monitor. (TV. Whatever)
HOWEVER;
Your laptop has at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Dunno. Laptop manufacturer and model number wasn't stated.
(One of the F keys at the top.
Generally;
Acer = F5
HP = F4
Lenovo/IBM = F10
Dell = F8, unless it's Alienware - F6)
Did that? That's how it worked on your friend's TV?
Then your TV is the problem.
Settings I assume. NOT a TV tech.
Regards,
joecoolvette
Feb 07, 2013 | Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I cant run my gateway GT5676 pc in normal mode with Samsung TV / Monitor
If I'm understand you correctly you said you have the HDMI Cable and the VGA Cable comming from the Computer to the TV. You should only have one cable. Either use the HDMI from the computer to the HDMI to the TV or use the VGA from the Computer to the VGA on the TV. Once you have the cable connect select your input on the TV. If you have the VGA Cable connected your input to select on the tv will probably be PC or Computer. If you use the HDMI Cable your input to select on the TV will be HDMI.
One you connect the cables and select the input try rebooting the computer and the video might show up automatically on the tv. If not you will have to hit the FN (Function key) + the correct (F1 thru F12) key that corresponds to the external display. The correct key will probably have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct key (F1 thru F12) that toggles the display. The display will toggle on 3 setups (Computer only, TV only, both the TV and Computer).
Now as for not being able to boot up normally that's another issue.
Apr 06, 2012 | Computers & Internet
My monitor wont recieve any signal from my computer
sir your monitor's VGA cable is not fine replace it and it will work fine get a new VGA cable from market and replace it then it will work fine.
Thank you
Mar 31, 2012 | Think Computer Computers & Internet
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
