USA cars? or not? learn that cars are not the same world wide. ok?
will if you had shopped for the part the seller shows all cars it fits.
so why not learn to at least shop and learn that, for free
or at the dealer that sells it, oops TOO OLD (most parts are from them even 10 years old)
gee and fit is not the ONLY factor, the pressure it regulates must be in PSI spec, or injections will be wrong for sure. out of spec.
what car is the target car, the post is contradictory, sorry./
what car is busted.
89 to 92
93 to 89
then a 90 is told,????
off hand I SAY NO.
AND FOUR SURE NO USED FPR THAT IS GOOD, EVER
THE intenral diapharm is no good now. 33years old new is best
my wild guess is
the car TO RUN is (target runner) is 89 D21 PU.
D21 ,centric answers. OLD old old 1989
The
D21 generation was the successor to the Datsun 720, sold as the Nissan Datsun Truck in Japan
this model was available worldwide !!!!!
The D21 series were called Nissan Hardbody in the United States/
so NO D21 here so said the wiki,
are you here
Nissan D21 (
Chile)
12 engines used world wide.
The
Nissan Pathfinder was derived from the Hardbody Truck and started in the same model year with chassis code WD21.
so AGAIN,what country is this 1989
and what engine is there, D21 list
the parts are NOt THE SAME, for sure FUELing. parts.
1.6 L Z16 I4
1.6 L NA16 I4[37]
1.8 L Z18 I4
2.0 L NA20 I4
2.0 L Z20 I4
2.4 L Z24 I4
2.4 L KA24E I4 (1990-1997)
3.0 L VG30i V6 (1986-1989)
3.0 L VG30E V6 (1990-1997) (no)
2.3 L TD23 I4 diesel (1987-1992)
2.5 L TD25 I4 diesel (1988-1996)
2.7 L TD27 I4 diesel (1988-1996)
I have lost the dash and tail lights, just all of a sudden. Also blowing fuse for illumination circuit. Have tried to isolate circuit and wire, but Haynes is not all that good. We are seeing dead short to ground. So was looking for service manual to get more accurate display of wiring.
I may have posted in the wrong area.I have no dash or tail lights. Just happened a few days ago. Nothing has been changed lately, nor any work done to truck. Has dead short in fuse panel for illumination circuit. Hoped it was headlight switch, but not it. Wanted better wire diagram than Haynes or Chilton's. They are too vague. This is a 1986.5 D21, standard, no extras, Z24, 5spd.
I checked out alldata.com, but think I will try local dealer first.If I have to pay, may as well be for the actual physical service manual I can have in my hand. I appreciate your response. Thanks.
Which system in particular? I have them all but way too many to post.
