Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Have 303447 briggs 16 hp only fires one cylinder
Have 303447 briggs 16 hp only fires one cylinder swap coils same one no fire both have 110 conpression what could be problem
  • 12,061 Answers
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Posted on Apr 23, 2010
  • brycesackett Feb 24, 2011
    Also check if there is a diode installed on the kill wire off the coil, it will be black. if the diodes are fried then that coil or both won't fire.
SNAPPER RIDING LAWN MOWER (CONVERTIBLE) / BRIGGS & STRATTON TWIN V MOTOR BY VANGUARD.
MODEL 303777,
TYPE1145-A1 (4756 UNDERNEATH THE 1145-A1)
CODE 95101011
PROBLEM, WHEN I TURN THE IGNITION KEY, IT IS JUST LIKE THERE IS NO BATTERY IN IT.
I HAVE DONE THE FOLLOWING:
THE NEW BATTERY IS FULLY CHARGED,
REPLACED THE INGITION SWITCH, SOLENOID, ALL KILL SWITCHES CHECK OUT OK, JUMP SOLENOID- THE MOTOR TURNS NORMAL BUT NO FIRE TO MAGNETOS, CLEANED FLYWHEEL OF RUST, ALSO THE MAGNETOS, GAPPED BACK TO .010, REMOVED FLYWHEEL AND CLEANNED ALL DIRT AND GRASS. HAVE CHECKED EACH WIRE FOR CONTINUETY. ALL OK.
THERE ARE TWO WIRES COMING FROM THE COIL UNDER THE FLYWHEEL, ONE RED THAT CHANGES TO A WHITE WIRE THAT GOES TO THE NEG. POST ON THE SOLENOID. THE OTHER WIRE FROM UNDER THE FLYWHEEL IS BLACK. IT GOES TO THE SAME CONNECTOR AS THE RED ONE DOES, HOWEVER IT GOES NO FARTHER, IT IS JUST PLACED IN THE CONNECTOR. I HAVE BEEN UNABLE TO FIND A WIRE DIAGRAM USING THE ABOVE NUMBERS FOR THE MOTOR.
THANKS IN ADVANCE.
Hh
Posted on Apr 20, 2011
Only firing one cylinder, replaced both plugs and one coil? What else could be causing this?
Justin, Did you replace the right coil, are the leads good,
Are both the triggering magnets still in the fly wheel,are they clean? Touch any piece of metal to both of them and make sure they are equal strength or close to it. If one magnet weak replace.
Twin cylinder briggs and stratton not firing on 1 side
22hp twin Briggs running on one cylinder at idle MyTractorForum com The...
Lawn tractor 1 cylinder not firing General Discussion Forum In Depth...
Briggs 422707 Firing one cylinder
Feb 09, 2016 | Garden
24 HP BRIGS V TWIN only 1 cylinder is firing what else can I check
No engine numbers to work with so here something to check. Briggs V-twins has set blocking diodes in the kill wire set. If one is shorted or leaky it will cause one coil to be dead if not both.
I just went this very same thing here a few weeks ago. In my case I started out one dead coil for sure installed new coil and still had no fire. Remove the kill wire as I normally do during testing in case a short and the new coil fired fine. Easier to just replace the wire harness then repair it. Out of curiosity I checked out the wiring harness and found one diode shorted and other one leaky.
Jun 01, 2015 | Garden
Jd lawn mower was only firing on 1 side coil and i changed coil so why is it still not firing
You only have one magneto on the flywheel, this is how any flywheel is designed because both cylinders can't fire at the same time, so why have two magnetos to fire one coil? Anyways, the magnetos on flywheels from my experience hardly if EVER go bad, and coils today have so many capacitors and resistors and diodes inside that even the slightest amount of heat soak from a poorly maintained engine can fry the circuitry and fault a coil in a flash. If you replaced te coil and it won't work, try to swap the coils around and see if the one you know works won't fire on that non-working cylinder, that way you can be sure the new coil is not defective, which I've seen many times as well. When it's running, do you pull the plug off the dead cylinder and see if it fires, then repeat the procedure on the live cylinder with the dead coil installed on the plug? Will it fire at all? Try to disconnect the kill wire from each coil, then start the engine and see if both cylinders fire now. I have seen some engines, as an example some briggs vanguard v-twins that have a diode right in the middle of the kill switch wire. I don't know why it's there, probably to deal with spikes in current or something, I'm not that great with electrical I just know how a simple ignition system works and I know if one coil fires that plug, the other one should too. As I said, things from china areive defective all the time, it wouldn't surprise me if that coil is defective or if it runs with the kill wire disconnected from the coils, then there may be a diode blown in the line or you have a chafed area of insulation that's grounding to the book somehow. Pull the kill wire and fire it up, then swap coils, you'll be able to tell what's wrong once you rule out one or the other, it's just a simple process of elimination for a simple problem once it's explained to you. I'm sure you'll figure it out and be back running in no time I you attempt my suggestions!
Jul 08, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 20 hp briggs and stratton that wont get any fire
Check the diodes in the wires to the coils. Trace the wires from the coils, and they should join together into a single wire. In the junction of the wires, there is diodes. There is a possibility the diodes burnt out which will not allow power to the coils. My experience was when one burnt out and only one cylinder would run. I replaced the wiring and both cylinders worked fine.
Jan 30, 2013 | Briggs & Stratton Briggs Stratton Intek V...
One cylinder not firing
First take the plug wire off the plug to the one not firing..start and then using a pair of pliers hold the plug wire away fro the plug insert a rubber handled screw driver in the plug wire and make screw driver contact with the plug end..there should be spark if the coil is good..if not that coil must be replaced...good luck
May 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1990 fxr with a single fire ignition, cam and s&s carb. I am not getting the rear cylinder to fire. I just cahnged the coil but no change. I have compression out the exhaust pipe for the rear...
With a single fire ignition, you cannot swap the wires. A dual fire ignition, yes, but not a single fire. You need two things to get the cylinders to fire, spark and compression. Take the plugs out of both cylinders. Run a compression test on the rear cylinder. You need at least 100 PSI to get the cylinder to fire like it should.
Next, put your plugs in the wires, (they should already be in the wiresand grounded) and spin the engine over. Watch for the plugs to spark,especially the rear plug. If you have spark and compression it should run on the rear cylinder. If it still doesn't run, either something is way wrong with the ignition or a very bad air leak on the intake.
If you don't have spark at the rear plug, you need to check the coil. A single fire coil is different from a dual fire coil. The primary wiring is different as well. If you've got the primary wired incorrectly, you won't get spark at the rear plug. Go to the website of the manufacturer of your ignition system. Most of them have downloadable installation instructions. Check your primary wiring.
Oct 02, 2009 | Harley Davidson FXDL Dyna Low Rider...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,852 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
