Question about Lexmark X5150 All-In-One InkJet Printer
Dirty Glass on Lexmark X5100
How do I get to the bottom side of the Glass on my printer to clean the Glass? It is very dirty and makes my scanned images look dirty.
Can you Help?
Thanks in advance,\
Mcmodelaman@Yahoo.com
  • Anonymous Apr 21, 2008
    I have the same problem, the glass on my x5150 looks as if it has smoke film on the under side, but it has never been in a smoke environment. It also has dust film. I would like to clean it but it looks as though I'll just toss it out and buy a new all in one since it is cheaper than having a local tech clean it. I'll think hard before buying another lexmark though.
  • stephenredin Jul 24, 2008
    I can't get a decent answer from Lexmark on this problem. They 'recommend' that I don't open it but offer no solution to the problem. And I can't seem to find a diagram/schematic on the unit to reverse engineer it open.
    Any idea how to open the unit up to clean it?
  • 148 Answers
Suggest you bring your printer to the nearest authorised repair center and have them do the cleaning...it will save you cost
Posted on Mar 23, 2008
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Horizontal lines on photocopies made but no lines appear when document document is printed.
Hi there, As it sounds its a dirty scanning glass. Open the top of the scanner so that you can see the scanning glass.. If your standing in front of it you will see on the left hand side a strip of thinner glass.. Take a damp cloth (better cloth with spirits/surgical alcohol) and clean the both the small and the large scanning glass. These lines normally cause if the glass is dirty. Especially if your using the document Feeder. As a lot of time wet ink or typex or correction fluid gets stuck on glass which will cause these lines.
Hope it helps
Regards,
Jul 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have a lexmark x560n printer. It will print from computer perfectly but when I scan or copy something the right side of the copy has the ghost image while the left5 side is perfect? Whats up with this?
Something is blocking the scan light. Dirty glass or something like that. Check the scanner glass and the scanner lid.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Oct 07, 2010 | Lexmark X560n Laser Printer
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
Receiver end of faxes shows vertical black line. I changed drum and toner also cleaned glass scanner. I do not have a glass flatbed scanner only an automatic feeder.
The cause of this problem is usually a dirty scanning glass (there might be ink or white out on the glass). Check the glass really closely or the cause could be dirty optics or a bad CCD board. There are mirrors underneath the scanning glass. Dirty optics can cause lines when faxing or copying. If you can not access these mirrors, they would have to cleaned by a technician.
Sep 08, 2009 | Brother MFC 4350 All-In-One Laser Printer
Vertical line appears on the faxed page sent to
This sounds like a dirty scanning glass in the adf feeder. clean the glass with a soft cloth. if this doesn't solve the problem, there might be dirty optics under the scanning glass.
Aug 03, 2009 | HP LaserJet 3050 All-In-One Printer
HP Laserjet3030 steaks/lines in flatbed photo scans.
Are printed pages clean?
If so, clean the narrow strip of glass on the left side of the main scan glass.
If printed pages are dirty as well, then probably a defective toner cartridge -replace
*please rate me:)
Mar 24, 2009 | HP LaserJet 3030 All-In-One Printer
Cleaning the Glass
OPEN THE SCANNER UNITE SIDE AND CLEAN OFF ALL DIRTS ON THE OTHER SIDE OF THE GLASS,COVER IT BACK AND HERE YOU GO...THE PRINTER SCANSS CLEAN AND CLEAR
Feb 05, 2009 | HP PSC 750 All-In-One InkJet Printer
Poor quality scan? Tips for cleaning this device
You can clean the scanner glass with warm water and a dust free cloth. Is the line always in the same spot in your scans? Could be something else other then dirty glass.
Aug 26, 2008 | Lexmark X1240 All-In-One InkJet Printer
Scanning glass dirty
hi,
not to worry... u can clean it with a lint free cloth.
thanks and regards
agnel
Dec 28, 2007 | HP Photosmart 2710 All-In-One InkJet...
Lexmark X5150 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
