Question about Microsoft Xbox 360 Console
Replace fan how can i change the fan in a plat station 3
  • 31 Answers
If your ps3 is undergoing problems i highly doubt it is the fan, and to find another fan would be pretty costly..
if you want to remove the fan you will have to peel off the warranty sticker
follow this guide to help you disassemble your ps3 and reassemble
http://playstationlifestyle.net/forums/showthread.php?s=1c5c4a67edf0622a086f41fbd739bf9a&t=2376
Posted on Apr 24, 2010
Why my htc explorer wont stop vibrating and cant power on.
your phone have hardware problem so go to the service station to resolve
May 16, 2017 | HTC Explorer A310e Black Android 2.3...
System error 21:10
first,unplugging the power cord for about 30 seconds then plug it again..if problem persist then follow next
Service Station failure. The possible cause could be:
1. The steps counted by the Service Station motor are not consistent
with the expected length of the current movement.
2. The Aerosol Fan has reached its maximum current limit.
3. The Service Station motor has shutdown because of blockage.
Corrective Action: Replace the Service Station/Aerosol Fan Assembly
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 19, 2013 | HP DesignJet 500 InkJet Printer
System error 21:10 hp designjet 500 plus
System Error: 21:10
Problem Description: Service Station failure.
1. The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
Corrective Action: Replace the Service Station/Aerosol Fan Assembly.
Aug 23, 2011 | HP DesignJet 5000 Printer
The light of License plat doesn't work. Who check or change the lights?
Is really easy;
1; remove the oil filter.
2; remove the tube where the oil filter gets screw, you will need a big deep socket I think is a 22mm
3 remove the two bolts that hold the cooler to the block
4 replace the rubber o ring for cooler and reinstall.
5 replace the metal o ring for the tube and reinstall.
6 install a new oil filter.
Jan 03, 2011 | 2002 Toyota Camry
I use alot of water..i changed my intake 3 months ago..i dnt see any water from weep hole..i did see my fan stop and start again..when i crank it ..it makes a rubbing noise by that fan and a chirping...
I would replace the fan clutch and see if that fixed it. You can check the water pump shaft after you switch fan clutches. Your water loss can be from overheating. Some Service stations have Radiator pressure testers and you might have your cap tested too.
Sometimes you can borrow tools from Autozone or Oreillys with a refundable deposit.
Nov 18, 2010 | 1997 Mercury Grand Marquis
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
What is hp500designjet code error 21:11
your service station is not working correctly. you will need to replace that assembly.
Nov 19, 2009 | HP DesignJet 500ps InkJet Printer
Fm radio station
You hold down the number on the face plat where you want the station set to.
Good Luck Please Rate
Dec 27, 2008 | Dual XDVD8181 Car Video Player
Plat station 3
Hello.
Your problem is from someone shoving a disc in. It has knocked the gears off alignment. It needs to be serviced by a pro or Sony.
I hope this helps! Good luck!!
Jul 16, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
