Question about HP Color LaserJet 3500 Printer
Hello, My HP 3500 is printing with a 2 inch wide grey streak on the right side. This is recent. Any ideas? Thanks
Try getting teflon sheet changed
Posted on Apr 23, 2010
I am having some very large, consistent streaks that just run across some of the top of my pages. If I print or copy out 20 pages only three or four will have this streak. It looks more like a stamping...
Sounds as though the fixing film assembly ( FM2-1793-020 ) in the fuser has developed a build up of toner causing what is normally called offset. You may also have to replace the lower pressure roller ( FC5-7207-010 ) also. You will have to remove the right side covers, door, and then the fuser assembly. Rebuilding the fuser has some challenges until you've done it a couple of times. Good Luck.
Jun 09, 2011 | Canon imageRUNNER 4570 Copier
Grey streak down the right side of the page 1/4 inch wide
Yip, its fuser film alright. You could pick up a fuser unit / kit from:
http://www.printersupplies.com/c-Laserjet3015Parts.html
and fix it yourself using the manual in this post:
http://www.fixya.com/support/t468332-fuser_removal_instructions_hp_laserjet
Best of luck
BD
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
My Ricoh 3500 color printer no longer is printing in color--just greys. It does not seem to be a problem with the color cartridges. Also, it streaks from left to right across a page from light to lighter...
The streaking could be anything internal to the printer, such as the transfer belt or a drum unit. As for the lack of color, that sounds like it is a setting in the print driver that got changed from printing in color to printing in monochrome or grayscale. Look through your print driver settings to see if you can locate this setting and change it back to color. Also, once you print in color again you may notice that the streaking is a specific color, which will help to troubleshoot that issue.
Jul 02, 2010 | Ricoh Aficio CL3500N Laser Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Printing
check your toner/drum cartridge. lift the flap, do not touch roller (usually green), is the same grey band on the roller, if so replace cartridge.
May 06, 2008 | HP LaserJet 3050 All-In-One Printer
Horizontal streak in screen
Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
HP Color LaserJet 3500 Printer Logo
312 people viewed this question
Seeker5211
Seeker5211
