Printer asks to be rebooted error 010-349 - Office Equipment & Supplies
  • 5,081 Answers
That is a fuser error.
Open the rear door. Remove and again replace the fuser.
If this does not work, you will need a new fuser.
Posted on Apr 23, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Apr 23, 2010
    Please donot forget to rate and accept my answer..
What does this error mean: Please reboot. printer (116-324);
power cycle the printer. switch off and on
see further here for similar printer error my okidata com
Jun 08, 2016 | OKI B6200 Laser Printer
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Oct 03, 2011 | Samsung CLP 315 Laser Printer
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
Keep getting error message after installing SmarThru: "installation of smarThru is not completed. you need to reboot..." but rebooting doesn't help - why?
your computer is asking for the reboot to delete some files cuz the installation failed so it will never working that way try the manual installation if you can dont use the auto-run disc
rather when it tells new hardware found click on it choose manually then select the files according to printer model
May 23, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Keeps showing 'add ink' after adding inks & turning off/on again
This method was for 8500/8550, but we have a 8560mfp and it worked for us (with some slight modifications...). Skip step #1 and do this instead to get to the Diagnostic Menu
Click the "System" button. Select "Information", then "Troubleshooting" then "Service Tools", and finally "Enter Diagnostic Mode".
"OK" below means the check mark button on our printer.
"This may include: Low ink error, add ink error or 09,035. Error codes and more.
1) Press and hold the red button (info button) and the "OK" button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the "Enter Diagnostics" menu. Select the "OK" button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select "ok" again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 "no test selected"
4) At this point hit the down arrow button until you reach the test #76. Select "OK"
5) It will ask for a confirmation. Select "OK" to confirm.
6) Then hit the down arrow button again and select the next test #75. Select "OK"
7) It will ask for a confirmation. Select "OK" to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. "Exit diagnostics."Select "OK".
9) It will ask for a confirmation. Select "OK" to confirm.
10) At this time the printer will again reboot for several minutes
Oct 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Get an error message when trying to print test page
Please uninstall your printer then reboot the computer. Make sure your printer is switched off, then insert your printer installation disk and follow the instructions. Do not turn the printer on unntil asked to.
Please post a new comment if you need further assistance.
Dec 13, 2008 | Epson Stylus C60 InkJet Printer
Error notice
Please reboot the Printer then check
Again reboot the Printer and PC both and then check. Let me know if the error still persists.
Regards
Ellin
Sep 25, 2008 | Lexmark T642 Laser Printer
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
32 people viewed this question
jasbo
jasbo
