Question about Dell XPS M1730 World of Warcraft Edition Laptop Computer PC Notebook
Wat is the adapter's valt for Dell XPS M1730 World of Warcraft laptop?
    Scholar:
  • 72 Answers
This is a 15 to 24 Volt, . Dimensions: 5.25 x 2.25 x 1.17
Thanks
Posted on Apr 23, 2010
Both fans stopped
Hi
make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
Dell xps will not boot ubcd
The cd-rom in the M1730 might not like the type/brand of disc you are using. An alternative would be to remove the HDD from the laptop and either put it in an external enclosure or get an adapter kit and hook it into another computer all together to recover your data. You can also try to make a bootable USB drive in order to boot the computer.
Apr 03, 2013 | Dell XPS 1330 1730 M1210
I couldnt use my mirco phone and make calls it shows cant detect ur sound card bt my speakers work wat shud i do my model is dell xps m1730
Go to the Dell website and make sure the drivers are installed for your laptop. There is a support page where you can enter the type of computer you have. Do that and it will bring you to a page of drivers. Look for the drivers for audio and microphone and save them to your computer. Then install. Hope this helps.
Mar 08, 2011 | Dell Computers & Internet
I reformat and forgot to backup...i lost my wi-fi...how do i know wat are the drivers i lost? and install them back...
Try looking up the specifications of your laptop using Google.
For example, try searching using the keywords Dell XPS M1730 Specs/Specifications
Once you found the correct result, look for the wireless device in the review. And there you go, now you know what wireless device you have on your laptop.
Hope this helps! :D
Sep 08, 2010 | Computers & Internet
Power adaptor type cant be deturmed
A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating.
Sep 07, 2010 | Dell XPS M1730 Laptop
The ac power adapter wattage and type cannot be determined . the battery may not charge.
Access the manufacturer's web-site for your DELL XPS laptop:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&catid=&impid=&SystemID=XPS_1730
Find the Dell XPS Service Tag on a sticker on the bottom of your laptop.
On the above page, click "System Configuration", and enter that ID,
to get a list of parts, including the AC power adapter, that was shipped with your computer.
Dec 02, 2009 | Dell XPS M1730 Laptop
Pa-19 power supply for my Dell m1730 is broken
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 08, 2009 | Dell XPS M1730 Laptop Computer PC...
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Dell XPS M1730 World of Warcraft Edition Laptop Computer   PC Notebook Logo
108 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
