Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How do you replace spring on a poulan chainsaw
How do you replace spring and rope starter on a poulan chainsaw, part numberp4018wt ?
    President:
  • 2,220 Answers
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 23, 2010
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
How to replace starter rope and spring on the 14" poulan. What's the trick for getting the spring wound and installed back in the housing?
There should be a mount inside the casing and another one on the starter rope socket. Wind all but a foot or so of your pull rope onto the sprocket then mount the spring on the mount in the casing. Don't worry about winding the spring yet. After that attack the spring to the sprocket. There should be a notch cut in the edge of the sprocket. Lay the rope in the notch and then place the spocket back into the case. With the rope in the notch you can then start winding up the spring taking the twists out of the rope as you do it. Depending on the length of your rope you'll probably need 5 or 6 turns of the sprocket. Once you get it wound then position the notch where the pull rope exits the housing. Grap the rope handle and pull the excess rope until it is all in the sprocket or outside the case and no longer in the notch. There might be some retainers for the sprocket. I"m not that familiar with Poulan. Secure these if there are some and put the housing back onto the saw and you should be good to go.
Nov 21, 2009 | Garden
I have a 18 in poulan wildthing chainsaw p4018wm the pull rope was jamed so i took it apart and wound it back but a small black spring fell out gave no idea were it goes i need a dirgram
What you have is the spring assist starter. This is a new style starter that does not engage with the flywheel in a direct basis as starters have don for the past 50 years. What happens is that you have two springs. One to recoil the rope and one to store energy to release to the flywheel in a sudden burst. If you do not like this type starter you should be able to buy the old style and replace it. Most of the parts list I have seen still show the old style starter. Check with a full service dealer in your area if you have one. If you can not find one in your area contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Sep 13, 2009 | Poulan Garden
I need help putting the metal spring back in. i
Hey if you look at poulan starter rope there is a solution posted for how to re-wrap the spring. ( it's actually pretty quick and easy to do ).
Jul 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
May 23, 2009 | Garden
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
719 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
