Question about Ovens
I need help connecting the wires from a blower motor to my Vulcan convection oven. The motor is for a vulcan convection oven SG-10-SME. The motor is a blower motor GE 419720-1. A repair man came out and installed the new motor, but cannot get the wiring right. On the line from the oven there are the following wires: 2 Blue wires with the numbers tags 53, and 54 on them 2 Red wires one with the number tag 98, and another with no number On the line from the Motor: 1 orange 2 red 2 white 1 black 1 brown See less Apr 23, 2010 - The product is a Vulcan Convection oven Model # SG-10-SME, The motor is a GE Model # 419720-1 1/3hp 1725RPM, h56yFrame See less
    Guru:
  • 1,049 Answers
Something seems wrong, or you have the wrong motor. These colors and number of connections don't make sense. I also can't find this model number you provided on the GE site. Are you sure the repair man ordered the correct part?
Posted on Apr 23, 2010
Have A Vulcan VC44gd oven that when you turn it on it trips the breaker. Where should I start.
Blower mtr would be a good start will it sit there until you turn on the power toggle switch.You could isolate the blwer mtr by un wiring directly at mtr.Beware there is a few wires in the junction one set of those wires are for the centrifugal switch(ie the fan has to be runnin for the oven to lite)
Feb 20, 2011 | Vulcan VC44GD Gas Double Oven
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Looks like our church just received the Vulcan VC4ED convection oven - 208 volts 60 amp. We have the 60 amp breaker but what gauge wire from the breaker to the oven do you recommend? I have to run about 35...
use 3 -- 6 gauge copper wires, you could get by with 2--6 gauge wires for the two hot phases and 1--8 gauge for the neutral connection,but with that long a run use all 6 gauge so you don't experience any voltage drop,also in your community you may need to check the local codes on grounding and need to add a separate grounding wire,which you can use an 8 gauge for this wire connection, if you use aluminum wire(which I highly DO NOT reccomend) you will need to get one gauge larger as in 3--4 gauge aluminum to carry the same current as copper wire
Dec 08, 2009 | Vulcan VC4ED Electric Single Oven
Vulcan SG4D convection oven is shutting off.
http://www.vulcanhart.com/manuals/F-35626.pdf
Since you were lacking a few specifics, go to this web site and it will have the service manual on your unit.
Hope this helps
Jul 23, 2009 | Vulcan SG4D Gas Single Oven
Vulcan convection oven has pilot lit and fan blows but no ignition. The schematic is too small, grease smeared and partly ripped to be of use. Is a schematic available or is the cause obvious to an...
The list of problems is as long as the one Obama inherited when he took over. Good news though, the most expensive part works, the blower motor! The pilot is established which rules out a gas issue. The two most common problems are, either the temp controller or the infinate switch is bad. Your unit has one or the other but, not both. Controller has several wires leading to it & has a green or tan circuit board on it, infinate switch is a small black or white 2 inch square box with 4 or 5 wires leading to it. Each one of these are mounted thru the front control panel & both have knobs. Temp board around $180, infinate switch around $45. As far as the schematic is concerned, Vulcan was bought by Hobart & they DO NOT give out schematics or service manuals.
Jul 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
I have vulcan Double stack electric ovens 208v 3ph.what size breaker do I need to power each oven
I need to know the Power rating Example 5Kw or the Ampere Ex. 30A . What is the raring of each oven? The Breaker should be greater than the Ampere of your oven let say 120% greater.
Jun 11, 2009 | Vulcan Convection Oven - VC44EC-208-3
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
