Question about LG RU-42PX10 42 in. HD-Ready Plasma Television
I have a lg rp42px11h I fix the vert lines now it flashe every 5 min after is on
  • LG Master
  • 12,061 Answers
You most likely have a problem with the voltage protection circuitry, the screen starts up, the crowbar is somehow activated, and it shuts it down, You need a service manual. Below, below that is a user manual, they have invaluable information, The service manual has troubleshooting and repair info found nowhere else.
http://74.125.155.132/search?q=cache:DmdPzTp_CKIJ:www.shema.ru/0_s/tv_1/goldstar_lg/RT_42PX20_Chassis_RF_043B_Service_manual.pdf+LG+RU-42PX10+service+manual&cd=37&hl=en&ct=clnk&gl=nz
http://www.retrevo.com/support/LG-RU-42PX10-TVs-manual/id/14714ci361/t/2/
Posted on Apr 23, 2010
Hi , I have a problem on my 62 inch lg plasma , First it had a black screen with a white verticle band then the screen went blue, I have volume but no picture.
Posted on Aug 06, 2011
Lg vertical line
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Vertical line faults to LCD displays; and most probable causes are given with illustrations.
Jul 24, 2014 | LG Televison & Video
After 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 01, 2014 | Samsung LN32D450G1D 32 LCD TV
Compaq presario 700. The screen, after running for about 5-10 min, gets white lines horiz. and vert. and then goes all white. I have to turn it off for a while and it goes away. (for 5-10 min)
The monitor heat sheild is probably damaged. If you don't have a warranty then you will probably have to replace the lcd panel on the computer.
Hook an external monitor up to it and verify that that screen doesn't scramble. if it does not and the lcd does then the lcd panel is damaged. if both do then you have a motherboard problem with the graphics card. either overheating or damaged. There is also a possibility of memory issues but the first 2 things i mentioned usually over this problem
Feb 12, 2010 | Compaq Presario 700 470024-192 Notebook
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Jan 28, 2010 | LG 42PC3D 42 in. Plasma Television
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
Vert deflection problem
You are correct about having a dry or leaky capacitor that is causing those lines to show on the top of the screen.
Check the caps with low capacitance like 1uf, 10uf, 47uf, etc.
No quicker fix for this one until you change the capacitors.
Hope this helps.
Mar 14, 2008 | Philips 32PT6441/37 32" TV
LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
913 people viewed this question
Computer Repairing
Computer Repairing
