DVP 9000S, the tray does not come out and stick
The tray does not come out and stick inside. Pull out the power cord for several hours and reconnect. Still no response to the button 'out'.
  • 12,061 Answers
This is a common problem, usually the eject drive motor, fails, or the circuitry, that drives it, or the brain, that tells, the drive to drive. There is no possible way to know, unless the unit is examined. You can sometimes get the tray open, by getting a straightened paper Clip, insert into a small hole at the front of the DVD tray, insert into hole, and push in, push, until a click, is heard/felt, and then push a little more past that point, and the tray should pop open, now you can at least get your DVD out. Now you either need to get this unit repaired or get a new one.
Posted on Apr 23, 2010
Media jam error
sir
Input tray area: If the page is sticking out of the input tray, try to remove it gently without tearing the page. If there is any resistance, see "Removing a jammed page" below Link.
HP Support document
Aug 24, 2013 | HP Vacuum Fan for DesignJet 9000s Series...
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Press the Power button (c01602202.gif ) to turn on the product.
  • Nov 11, 2010 | HP LaserJet 2430dtn Printer
    All in one printer displays clear paper jam then press ok, but no paper jam can be found on printer. hp photosmart c5380 all in one.
    There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert HP technician to mend it.
    Sep 25, 2010 | HP Photosmart C5380 All-In-One Laser...
    I need to hack the region of the Sony DVD SR500H
    Hi there
    Follow these steps and your dvd will be able to play discs from any region.
    *With the player in stand-by mode (take out any discs and leave it alone for several minutes) press on the remote, in this order: TOP MENU, CLEAR, POWER.
    *A menu will appear with several options. Choose Option 2 and then Option 4.
    *Type 12450, press enter, then type 00000.
  • Step 4 After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
    *After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
    Thank you for visiting
  • Step 2 A menu will appear with several options. Choose Option 2 and then Option 4.
  • Step 3 Type 12450, press enter, then type 00000.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
    Jul 27, 2010 | Televison & Video
    Cd compartment wont open and it is locked dvp sr200p sony
    Ensure the child lock feature is disabled. Try Power resetting the Player.
    Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
    If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
    If the issue still persists, service might be required.
    Jul 26, 2010 | Sony DVP-SR200P DVD Player
    Unlock Sony DVP NS725p
    Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
    Jul 24, 2010 | Sony DVP-NS725P DVD Player
    My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
    Hi!
    here are some solutions for your carriage jam error.
    1. Clear any jam...remove loose paper.
    2.Clear the jam from the back of the printer
    turn off the printer...remove the rear access door..
    pull the paper out of the roller and return the rear access door.
    3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
    disconnect the power cable from the back.. remove the paper output tray.
    look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
    4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
    disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
    And lastly after doing this steps try to reset the printer and try to print..
    To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
    Good luck! hope this solve the problem
    Much appreciated if you rate this help.. thanks
    May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
    Says have paper jam when there is no paper in the printer
    see what you gotta understand
    is that right next to the
    rollers that pick up the paper
    are paper sensors so if those
    sensors have been damaged take
    a cotton swab dip it in water.
    clean the rollers where the
    paper is taken in from and
    also clean the carriage rod
    along which ur cartridges
    move(metallic rod).
    Remove any loose paper from the input tray. Press the Power button (c01345237.gif ) to turn off the product.Disconnect the power cord from the back of the product.
    1. Gently pull any jammed paper out of the rollers in the back of the product.
    2. Rotate the rollers upward to make sure that they move.
    3. Clear any paper jammed paper from inside the duplexer.
      1. With the wheels facing toward you, unlock the duplexer by pulling back the gray levers on each end of the duplexer.
      2. Open the duplexer lid.
      3. Remove any paper from inside the duplexer.
      4. Close the duplexer lid.
      5. Lock the duplexer by pushing the gray levers up and forward until they snap into place.
    Before reattaching the duplexer to the back of the product, follow these steps to clean the paper rollers to remove any debris, dirt, or paper scraps.
    1. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward with your fingers to clean all the way around.
    2. Allow the rollers to dry completely.
    3. Reattach the duplexer to the back of the product. Gently push the duplexer forward until it snaps into place.
    4. Reconnect the power cord to the back of the product.
    5. Press the Power button (c01345237.gif ) to turn on the product.
    6. Load paper in the paper tray.
    7. Try the print job again.
      • If the error message displays again, proceed to the next step.
      • If the pages print successfully, you do not need to continue troubleshooting.
    Follow these steps to clear the jam from the automatic document feeder (ADF).Remove all originals from the document feeder tray.
    1. Lift the cover of the ADF.
    2. Lift the ADF mechanism.
    3. Gently pull the paper out of the ADF mechanism.
    4. Lower the ADF mechanism.
    5. Close the ADF cover. Press down until the cover snaps into place.P
    1. ull out the main input tray.
    2. Slide the paper-width and paper-length guides to their outermost positions.Insert a stack of paper into the main input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
    3. Slide the paper-width and paper-length guides inward until they stop at the edges of the paper.
    4. Push the main input tray back into the product.
    5. Pull the output tray extender towards you, as far as it will go
    1. Press the Power button (c01346625.gif ) to turn the product off.
    2. Disconnect the power cord and the USB cable from the product.
    3. Unplug the power cord from the wall outlet.
    4. Reconnect the power cord and the USB cable to the product.
    5. Plug the power cord back into the wall outlet.
    6. Press the Power button (c01346625.gif ) to turn the product on.
    Jun 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Dvd tray will not open
    In order to open the disc tray.apply one of the following solutions;
    --- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
    Plug the power cord back into the AC outlet. Try to open the disc tray.
    --- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
    --- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
    - If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
    If the problem is still unresolved, a service may be required.
    good luck...
    Apr 06, 2008 | Sony DVP-NS400D DVD Player
    Televison & Video Logo
    119 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
