Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision model number 42hds69 cable problem.
I recently bought a hitachi ultravision model number 42hds69 from a guy at work, i just got cable in my new appt and i tried to hook it up but its not working, i go to the air input and it does nothing, can anyone help me>
  • Hitachi Master
  • 12,061 Answers
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Posted on Apr 23, 2010
Hitachi ultravision is hot, to the touch, Is there concern?
I've owned a 42HDX99 since 2007, It's always been warm/hot. Still works/looks Awesome. Plasmas do generally run hotter than
LCD/LED's. Also have a 58" Samsung Plasma ( which I've had to repair ) and a 2009 Toshiba 1080P LCD ( still works great )
Aug 27, 2014 | Hitachi 42HDS69 42 in. Plasma Television
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
Intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Nov 12, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical Green Bar 3" wide on the right side of my 42" plasma
My thought is that it is an Intergrated Circuit (IC). But it has been brought to my attention that it may be as simple as adding a "ground adapter" to the plug of the TV. If after you try changing out the ground adapter and it doesn't work, try "power cycling" your TV. (unpluging it... Waiting 30 seconds, then plug it back in.) If that fails, contact Hitachi so they can recommend an authorized service center in your area. Hope this helps. Good luck, KMarshall!
May 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Picture went out when I changed the cable channel
Check this forum thread:
http://www.avsforum.com/avs-vb/showthread.php?t=778593
Jan 27, 2009 | Hitachi 42HDS69 42 in. Plasma Television
HITACHI 42HDS69 connect to PC
I have the same question /problem. I recently ordered a cable that has the a computer monitor connection on one end and the "s-video"connection on the other end. This might work. I will post a new reply when I get the cable sometime between 8/4-8/7; if it works I will post a new message
Mightwork
Jul 10, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
674 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
