Question about Admiral AW22 Top Load Washer
Spining when i start the washer it work good but then when its mixing up the clothes in the beginning the thing in the middle gets stuck /slows down can u help me ?
    Scholar:
  • 116 Answers
More than likely a loose agitator, remove the cap in the centre of the spindle where you put your conditioner by pulling, inside deep down you will see a 17mm bolt, tighten using a socket and long extension, you should remove the agitator to see if there is any damage or wear to the agitator plastic splines before securing fully. Simply undo the 17mm bolt and lift the whole agitator out in one.
Posted on Apr 13, 2008
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Not spining out good. Looks like its spining slow
Make certain that the spin speed is where you want it (e.g.: high spin). Also, make certain that you aren't overloading the washer. A heavier load will slow down the spin.
You may have a worn drive belt (loss its tension on the pulley). Contact an appliance service company.
Feb 20, 2010 | Amana NAV5805A Top Load Washer
Not draining all the way. slow spin
replace the door switch my washer did the same thing. switch is very easy to replace
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Ticking/chirping sound during slow spin
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
Aug 22, 2007 | Bosch WFMC 3200 Front Load Washer
My washer wont empty out while spining.
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Admiral AW22 Top Load Washer Logo
83 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
