Question about Saitek (PS28) Joystick, Throttle
The throttle is stuck open on my Saitek 3D Pro, how can I fix it? Multiple calibrations thru FSX have proved unsuccesfull. It's hard to finish a landing with it open
  • 122 Answers
You need to completely remove the calibration you have done. uninstall the driver, reboot and then connect stick back up. Follow on-screen prompts for the driver disk and reinstall. Check there are no conflicts in the sticks own software once installed, then calibrate it.
If still no go, then the stick is faulty.
Posted on Jul 12, 2010
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
I have a Saitek Pro Flight Yoke System with Throttle Quad and it works fantastic with MS FSX, but if I try to use it with my Proflight, as soon as it starts, it does a wild left hand turn and just gets...
Try to get the latest drivers from www.saitek.com
Try it on another computer and if it does the same there too you might want to consider that it can be faulty...and you might want to request a replacement for it.
Hope it helps..
Apr 24, 2011 | Saitek Pro Flight Yoke System Flight...
I have the Logitech wingman Extreme Digital 3D Joystick but when I play fsx the speed thinge is not woking. For instance when I put it at 100% it only goes to like 70% and when I put it to itle it its a...
You need to calibrate this function from the settings page (found on the opening screen). Go to controls, then calibrate. All buttons, levers and sliders need to be calibrated otherwise FSX doen't understand what range it should have. Just select this controller, go to calibrate and do what it says on the screen and it will sort it,
Jul 13, 2010 | Logitech WingMan Extreme Digital 3D...
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
I'm in Belgium fan of fsx with window 7 64bits with saitek x52 pilot 6.0.4.1(HID-USB) All the bitton are working except one : the twit (rudder). It makes a mouvement (kind of vibrations) around the the...
You should set this axis up first as a rudder in FSX settings, then calibrate it. Make sure you hav the latest drivers for it too. Make sure that Auto-rudder check box is unticked. I hope this helps, good luck
May 08, 2010 | Saitek X52 Flight Control System
On saitek yoke system it wont work on fsx *flight simulator x* if you can help thanks !!!!!!!!!!!!!!!!!!!!!!!
Ensure you have installed the drivers for it. If you don't have them, go to Saitek web site, download and install the correct one's for your operating system. Also ensure that the yoke is plugged into the USB port on the rear of the PC as these USB sockets give the most power. Additionally, you have to set the yoke up in FSX\Settings so it knows what to do with it with regard to calibrating it and assigning what buttons do what.
Sep 07, 2009 | Saitek Pro Flight Yoke System Flight...
SPOT VIEW FIXED
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
Apr 22, 2009 | Saitek Pro Flight Yoke System Flight...
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Using Pro Flight Yoke, etc. in fsx
To keep the settings in FSX you must got to the main page, choose settings, create your settings then save the configuration file with a name, ie "myconfig.cfg" or something you will recognise,
Don't try to do the settings from within the game from the top menus as they are not saved this way. Exit the game back to the start screen and do your settings from there, This will fix it. Good luck.
Jun 02, 2008 | Saitek (PS28) Joystick, Throttle
Saitek (PS28) Joystick, Throttle Logo
250 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
