Question about Dell Inspiron 6000 Notebook
Cant connect to 2wire dsl cant see network wirelessnot switched ?
How to switch on wireless
  • 43 Answers
Firstly does it have a wireless indicator somewhere on the laptop?
most of the indicators located next to bluetooth switch and other indicates. once you identify the indicated then you can solve this problem.
check you wireless network settings. if not the device is disabled or drivers not installed.
if your device is ok, then you check the software for the wireless network. most computers do not indicate that the wireless device is working, try to install a wireless application driver for your laptop and try connecting it a wireless device to see if there is any connectivity.
thank you
colticz
Posted on Apr 23, 2010
I can I connect this with a DSL modem/router (2Wire). Ideally I'd like the linksys to do the routing
This can not happen. It is a switch, and not a managed switch at that,
Just let the 2Wire do the routing.
Sep 01, 2010 | Linksys SR224 24Port Ethernet Switch
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
My laptop can't connect via wireless to my att/dsl 2wire wireless router/modem. it see's it but cant connect
Hi toasoulinh,
First off you need to go to your network connections, and right click on the wireless connection and view status. Then click on the support tab, and then the details tab. This will show you what the IP configuration is. You need to have a gateway (which is your wireless router IP) and a assigned IP address for the laptop, and also a dns IP to resolve who you are. I'm going to guess that one of them are missing, perhaps the DNS? If there is any missing click on the repair button, and see if it corrects the problem. If not, then you have a bigger problem then you bargined for. You will need to go to your network connection and click on wireless connection. Inside you will find a add wireless connection button. Click this button and windows will walk you through creating a new connection. If that doen't to the trick.
You can reconfigure your HomePortal without using the setup CD.
  • Open your Web browser.
  • Type http://homeportal/setup in the address or location line of your browser.
  • Follow the on-screen instructions to complete the setup process.
    • If you need a key code, you can find it at HERE
    • If you need to replace drivers for your 2Wire network adapters, you can download them directly from the 2Wire support Web site.
Good Luck,
And don't leave a rating
Thanks
Mark
Sep 21, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire wireless connection problem
Make sure that the wireless switch on your laptop is on. Click on view wireless network by right clicking on the network icon on your system tray. Locate the name of your modem ( SSID ) & enter the wireless encryption key ( WEP ) or password
Apr 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Problem with 2wire adaptor connecting to Avenue Broadband
Yes, The DSL connection and Broadband connection are different with each other.
You'll needing to reconfigure the router as Dynamic and clone the MAC address so that it will recognize to the network.
- Try resetting the router and reconfigure the settings of your router.
Mar 05, 2009 | 2wire HomePortal 100 Network Adapter
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
Laptop not connectiong to wireless network
is there a switch on the laptop either in the power management software or an actual switch on the laptop case (or a button) that turns the wireless on and off? That's probably the problem, not your router.
Aug 18, 2007 | 2wire 2700HG-B Router (2700HGB)
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Dell Inspiron 6000 Notebook Logo
383 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
