Question about Compaq Creative Sound Blaster PCI 128 Sound Card
My two right hand usb ports are not working!
Two weeks ago i pluged my camera then printer into the left hand port then after i had unplugged the printer my mouse would not work in the ports on the right hand side,i have tried Device manager and many other solutions but nothing will fix it so can you help me please.
    Scholar:
  • 90 Answers
Three questions that will resolve the issue:
1. Did the printer work? Was it working till the end when you unplugged it?
2. Hopefully you have tried the same devices in other ports and they are working. Else the device maybe faulty.
3. Is the device manager showing any components without drivers?
If the above three points are ok, you may have the seldom case of USB short circuit. USB has power lines. They normally dont short so easy - but things happen.
I would say - ignore the ports. Buy a cheap new hub and use it in one of the working ports. That is your best and cheapest solution.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
  • 3 Answers
Open the system and check the connections
I pluged in the usb port & then to my camera. does
1) Check if both the camera and computer on.
2)The camera can be turned on only after the usb cable is conected to computer first and then to camera
3)Check another usb port
4)Check another cable
May 10, 2011 | Samsung Digimax 420 Digital Camera
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=All&x=27&y=14
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Mar 31, 2009 | Epson Perfection V500 Flatbed Scanner
Usb ports not responding
Ports are need to be re soldered or replaced.
Mar 18, 2009 | Computers & Internet
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
USB Power Surge Error
normally usb ports are plug/play it could be tht there is something wrong with your usb cable if i knew your mailing address i could send you a usb cable i have tons..
Sep 26, 2007 | Vivitar ViviCam 5385 Digital Camera
Printer doesn't work
The answer is probably down to the usb port, they don't always like change, because you are trying to swap hardware in same port, they tend to want to stay with one or the other peice of hardware. If you have'nt got another spare USB port, which i assume you have'nt, invest in a 2 or 4 port USB hub(But make sure it's powered by a AC power lead and not just a usb powered hub, because some hardware will not be recognised e.g I Pods), this connects into your usb port and gives you 2 or 4 port more to use, and you won't need drivers for it. They are inexpensive and you simply plug it in. I think this will solve it for you
Oct 23, 2006 | Samsung ML 2010 Laser Printer
S75 & Mem Stick Reader Help
I had the same concern a month ago when I bought my USB Stick reader. As you mentioned, the manual says there is no guarantee... I don't have a USB hub but I do use the USB port that I connect the USB Stick reader for other things. No problem. In fact I did not even have to use the supplied CD that came with the reader to install the driver for it. As soon as I pluged the reader to the USB port. Windows ME (yes I'm running WindowsME) found the device and install the built-in driver itself. Why don't you just wait until you get your camera and try it out first. Good luck.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Compaq Creative Sound Blaster PCI 128 Sound Card Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
