Air cond & electrical outlet in 1999 sprinter by keystone 33 ft
My electrical out let in my 1999 sprinter by keystone in the kitchen area has a electrical burning smell and so does my airconditioner but the othere out lets are fine is there a fuse or breaker panel where is that and could it just be the plug outlet doesnt have manuel do u know where i could find one? and the fuse or breaker box?
  • 6,674 Answers
One of your breakers in your main panel should be for either one of those. Simply test receptacle for power as you try flipping each breaker off and on, until you find the right one. Quite often a high amperage draw item like electric frying pan, or hotplate plugged into the one by the kitchen area is the culprit. If they smell, or appear burnt or scorched, they should be changed, as well as the entire circuit tested for proper size wiring, as well as rated receptacle to handle big power( amperage draw). Extension cords will also cause same problem. Make sure if you have to use an extension cord, that is a heavier gauge wire, approved for that use, and is as short as possible. I'm assuming your AC is plugged in to a receptacle, and not on roof?
Posted on Apr 23, 2010
I want to know the locations of the water pipes
between floor and underbelly try using air through city water no more than 40 lbs
May 23, 2018 | RVs
What breaker in the 120V part of the power panel provides 120V AC to the refrigerator outlet? There is no dedicated breaker for it.
remove fridge vent panel exactly outside fridge see if voltage to outlet its plugged into if voltage and runs on LP then bad heater element if no voltage check gfci outlet inside unit
May 19, 2016 | Keystone 2008 Sprinter 272RLS
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
Just bought a 2008 sprinter RV 272RLS and I need a owners manual for it.
Best to contact Keystone's Customer Service (as no one one here has any manuals).
Apr 30, 2015 | Keystone 2008 Sprinter 272RLS
Why won't my blank tank drain
On some later model Montana 5th wheels, there are actually three holding tanks which will eventually require draining. (two grey tanks, 1 for the kitchen sink(s) and 1 for the bath tub & bathroom sink, and one black tank, obviously the toilet...) The two most used drain valves (1 black & 1 grey) are together in the docking station area where the city water supply is hooked up, the other (kitchen sink) is at the left rear of the coach behind the farthest rear wheel along the frame. (That is where "Keystone" installed the grey tank for the galley, or kitchen if you prefer.)
If certain it is the black tank which won't dump when the black tank valve is pulled, there is a restriction before the valve (or the valve itself is not opening hence a broken cable to the valve?) One might try "snaking" up into the sewer line, measuring the distance from the outlet to the valve location, assuring it is either open or closed. Once that has been determined, you will at that point have to remove the sewer line at the valve for repair. Be sure to wear latex gloves and eye protection and have a drain pan or bucket handy for spillage which can be collected and dumped down your home toilet or outside sewer clean out if you know its location.
May 21, 2014 | Keystone 2011 Montana Hickory Edition...
Is rebuilding the air cond. clutch or just buy new one the way to go and which will be cheaper?
Since you said HAVE IT REBUILT & your not doing your
own work
Then go with the new clutch,IF the old compressor DOES
NOT LEAK REFRIGERANT
Cost is subjective & not my area of expertise,I do all my own work
& get discounts on parts
Sep 13, 2012 | 1999 Ford Crown Victoria
Have a 2006 dodge sprinter trouble code p0107..
Map sensor bad or vacuum &/or power to it missing. Map sensor located on intake manifold or firewall. It has a vacuum hose & electrical connector attached to it. To verify it is bad disconnect electrical connector to it while running. Idle should smooth out & run good. If so need to replace.
Jun 15, 2010 | 2007 Dodge Sprinter
We have a GTS18HBSW Fridge, had it for 3 years. Just started making a loud motor noise from the fan area. Sounds like I have a truck in my kitchen.
Likely to be hitting ice that has built up around evaporator in the back of freezer. It's cliche, but try defrosting.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | GE GTS18HBSWW 28" 18.2 Cu. Ft. Top-Freezer...
1999 vw air cond.
go to advance or auto zone and they got a gauge on there cans and some without cans that will tell you if you psi. should be at. on them they should read in the green area.
Sep 13, 2008 | 1998 Volkswagen Beetle
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
