Question about EuroTech EWF150 Front Load Washer
Excessive vibrating My eurotech EWF150 is new and we've only used it about three times. The first time was fine but now I notice that it vibraes excessively. I'm not sure what the problem is and I know its leveled because we have continually checked that it's not the problem. It starts to vibrate alot when its near the end of the spinning cycle. Now the detergent compartment wants to stick out and leak and that was never a problem until the vibrations started. Does anyone know how to fix this or atleast what the problem is? Please help!!!
See if the the plastic shipping cones have been removed from the bottom.
Posted on Nov 01, 2008
SOURCE:
Eurotech EWF150 doesn't centrifuge
Check that the drive belt so in good condition & replace if worn, or Replace the timer switch, can be bought online.
Dec 15, 2013 | EuroTech EWF150 Front Load Washer
I have a Eurotech EWF150 frontload washer that does not spin. The drum will turn for rinse and wash cycle, but not spin. We checked the motorboard and there are 2 spots that appears burned. Hubby is trying...
I am not 100% sure your problem is the same as the one i had with my frigidare front loader but my door lock switch went bad. it would wash fine but when it came time to spin it only would tumble.
Jan 02, 2012 | EuroTech EWF150 Front Load Washer
My washer fills up with water and nothing else,the motor still runs but it doesnt spin wash nothing
As you said in the question you are using Euro Tech EWF 150 you are washing machine have problem with the belt.Belt will be damaged you just need to contact the nearest washing machine center so that you are washing machine will be just fine.There is no big problem it's just a small problem.If you no how to fix that belt means you can fix the problem.Thanks for your question.
Jun 19, 2011 | EuroTech EWF150 Front Load Washer
Where can I obtain a new power cord for a Eurotech EWF150 washer?
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 03, 2011 | EuroTech EWF150 Front Load Washer
The washing machine works fine the only thing is that the spin doesn't work, it starts but never gets to it's optimal speed. Clothes are soaking wet when the cycle ends. Our washing machine is a...
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
May 09, 2011 | EuroTech EWF150 Front Load Washer
Hi 5800 only vibrate no on
1. By using a scale manually Multitester x1, connect the cables Multitester with positive and negative poles of the Vibra component, if the component is vibrating in a good situation, but if the components do not vibrate Vibra then you need to replace the defective component Vibra.
2. Further examination could be done if the component is not damaged and remained Vibra still using Multitester, connect the cable to the interface component Multiterster Vibra on phone PCB, if there is movement of the needle when it is connected Multitester the path under normal circumstances, otherwise if there is no needle movement means there is a path Multitester end. You can make jumpers system directly from the UI to the component controller IC Vibra. Check also that the positive path from the battery to the Vibra in good condition, if the track is lost then do the path-breaking jumper on you, then the vibration will work again.
exsample image on nokia n95
look
http://1.bp.blogspot.com/_y-JFYukllP4/S4p0DjmWvlI/AAAAAAAACGk/4wjfgVRipqw/s400/vibra%20N95.jpg
Apr 25, 2011 | Nokia 5800 XpressMusic Smartphone
The spin cycle doesnt seem to be working - clothes are coming out soaking wet - what could it be
Overloading, see if ur spin cycle wok ok by doing a empty load and watching it
Oct 26, 2009 | EuroTech EWF150 Front Load Washer
Vibrate on
good day ! you need bring your phone to the cellphone technitian to check the vibra motor or the setting of your phone , if the setting is good thats mean the problem is the vibra motor or the vibra driver ic try to replace that ! good luck ! ...
Sep 09, 2008 | Sony Ericsson W200i Cellular Phone
Does not agitate
Motor coupler could be bad.
Dec 10, 2007 | EuroTech EWF150 Front Load Washer
EuroTech EWF150 Front Load Washer Logo
160 people viewed this question
Top EuroTech Washing Machines Experts
Poppa Maddo
Poppa Maddo
vince
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
