Question about HP PSC 1410v All-in-One Printer
My software won't complete the download - HP PSC 1410v All-in-One Printer
    President:
  • 1,768 Answers
You may have a dirty or corrupted data disk and needs replacement.
Clean your disk with warm water a dish detergent and dry with a microfiber towel or cotton bath towel and try again.
Posted on Apr 23, 2010
My games won`t load properly
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Aug 22, 2012 | wooga - world of gaming Monster World
Toshiba Satelitte A500-17X Bios Update Fail, I was asked to update this software and then it downloaded the file and installed it. Now the laptop does not turn on
The bios is corrupted because it was not able to complete the download, or there was a power interuption corrupting the data, and finally the wrong file was downloaded. The only thing you can try is remove the main battery and disconnect the power supply from the laptop and press and hold power fot 60 seconds, then plug everything back in and try to restart the laptop, probably won't work.
Jul 11, 2012 | Toshiba Satellite P105-S6197 Laptop
Why won't my blackberry torch turn on completely?
This may be due to the following reasons:
1. The battery may be down. Recharge.
2. Your firmware(Blackberry OS) may be corrupt due to some physical or software problem.. Try to Update it.
3. Some lastly installed software/app may be causing any problems.. Try to Restore device settings from backup..
4. The last installation may require device rebooting and it is nmt able to do that...
Jan 01, 2012 | Motorola Cell Phones
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have no disc for my new epson sx115 so it won't install into my pc. i tried downloading the drivers from the net but no luck so far .... hpoe ya can help me
Click HERE - download the software and it will work for you as this is the same as a disk. Be sure to download the support software/drive for the operating system you have. - XP - Vista - 7 etc.
Gary @ Fix Ya
Sep 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How can i downlod software and drivers of hp officejet 5610 all in one printer
You go to their website located at www.hp.com. Click on support and then downloads and enter your make and model of printer. Find the download for your pc's operating system and click on it. Follow the prompts to download and then install the software on your computer. Remember not to connect the cable from the pc to the printer until the software has been installed.
Jul 17, 2011 | HP Officejet 5610 All-In-One InkJet...
Is fully charged but completely blank. Won't work. A sim card problem? Have used this for six months or so.
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jun 29, 2011 | Cell Phones
Changed my acer PC Veritron 6800 from Spanish to english and lost the sound. Downladed the driver from Acer but in a win zip file that i cant get work
Install a WinZip software to get your download open. You can have it by connecting to the internet and type at the search engine (free download Winzip software) and click on it, to get your download. Upon completion, go back to your PC. Click open the Winzip download and install it. Upon completing the installation, go back to your downloaded sound driver software, Click open, and install it. After completing
the installation of your sound driver software, test it
using the Windows Media Player. Hope this help you.
Nov 24, 2009 | Acer (54.AA806.001) Sound Card
HP PSC 1410v All-in-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
