Question about Apple iMac G5 Desktop
I have a white line vetically down the middle of my screen
Will this get worse? Is there a way to remedy it ?
    Problem Solver:
  • 16 Answers
This is a problem with your screen caused by excessive use, not turning the computer off or not allowing the display to sleep. More lines will appear if you continue treating it as you have; go into System Preferences --> Energy Saver and change the Display Sleep time to be shorter, like 15 minutes or so and check the "Automatically reduce brightness before display goes to sleep" box. Hopefully it will not get worse or you can live with lines on the screen, otherwise you will need to replace the screen which could cost roughly half or more of the cost of the actual Desktop.
Posted on May 03, 2010
White line in center..sound iis fine
Most common are soldering problems on the vertical deflection IC's.
If this line is quite bright: shut down the set, it might damage the picture tube permanently. Resolder all pcb connections under the vertical defl. part. With a magnifier you can see "craters" around the footprints. Where is the vert. deflection. ? Mostly an integrated circuit
on a vetically mounted heatsink . Typnumber: mostly something TDA53xx like. Gently knocking with a screwdriver and observing the screen might lead you to it's location if you're not familiar with TV's.
Watch out: lethal voltages !
Jan 27, 2014 | Panasonic CT-32SL14 32" TV
Lines on screen
i have, a lg pdp50x30010 it has a white screen with vetical colour bands which move across screen can have replaced main board and av board and driver panel can you help pls.
Jan 09, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
Horizontal line running through the middle tv screen, no picture but has sound. TV is a Toshiba.
You haven't vertical deflection.
The ff caused the problem.
1. Dry joints on the vetical section.
2. Blew Vertical ouput IC
3. Open yoke vetical winding.
4. No vertical output from jungle IC.
5. Open supply for vetical ic due to open fusible resistor.
I've suspect that you have #1 and #2 fault. This is not Diy so I've advice you to send to repair shop or look for a qualified tech to isolate the problem.
Thanks for using fixya.
Jan 26, 2011 | Toshiba Televison & Video
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
The tv has a 3" white verticle white line down the middle
Sounds like your LCD panel is failinf and will need to be replaced it is going to be costly around 1500
Nov 29, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Apple iMac G5 Desktop Logo
804 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
