Hp hard drive 400gb
Thee beeper of thee hard drive it keep on beeping when i turn the hard drive on
    Sergeant:
  • 349 Answers
If you mean when you turn the pc on (hard drive on) it beeps, then you have a hardware problem,and you need to fault find what hardware has failed.
please provide more information so i can help you
cheers
Terry
Posted on Mar 25, 2008
SOURCE:
It says no boot device
>Do you have an operating system installed on that drive? If you have an operating system installed on that drive and are trying to boot from that drive, check and see if your BIOS will allow that. Many will not. The beeping is not coming from the external drive, it is coming from your computer's system beeper. Usually those beeps are in a pattern that is a code for what the problem is. Check your computer manual booklet.
Mar 06, 2014 | Iomega 500GB Prestige USB 2.0 Portable...
Is it possible to connect the HP xb3000 to an apple computer
It's only possible if the main connector will fit into the apple. I haven't seen the female connectors of apple computers lately, but I'd bet that the HP XB3000 connector will only fit into an HP Laptop.
Oct 14, 2012 | HP Xb3000 Notebook Expansion Base And...
My hp hb2000 expansion base hard drive is no longer accessible. Has been fine for years and disappeared from My Computer overnight. Please help
Does it show up in Disk Management?
http://www.windowsreference.com/windows-vista/how-to-use-disk-management-in-vista/
If you need data recovery this guy does it remotely off of donations.
http://FreeDataRecovery.us
May 21, 2011 | HP Xb3000 Notebook Expansion Base And...
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
My hp pavilion will not charge with connected wire that is plugged into outlet; it seems stripped?
outlet plug on laptop damaged you will have to send it to someone who can replace the outlet for you unless still under warrenty then you can send it to HP for repair
Feb 07, 2010 | HP Xb3000 Notebook Expansion Base And...
Hitachi 400GB internl drive not seen.
Initially, pls :
  • check/replace IDE cable used;
  • check power connector;
  • verify master/slave jumper setting;
  • reset CMOS/BIOS to default;
  • change motherboard IDE connection from IDE1 to IDE2 or vice versa;
  • try as a standalone, temporarily remove any other IDE device such as the DVD/CD.
If all else fails and thee HDD works/checks OK in other machines, you may need to update the BIOS of the Asus A8V deluxe. Pls start here. Click on "DOWNLOAD", on the :Input Model to Search" type A8V, in Select Category, choose BIOS, click on Search Info button, follow on screen instructions
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
