Question about Cameras
My camera will not turn on, and i tried different batteries and it will not turn on
  • 1 more comment
  • mill brad Mar 23, 2008
    It was working fine and now it wont turn on i tryed different batteries and plugging it in my computer but nothing
    It wont turn on even when i put new batteries and i tryed plugging it in my computer but nothign
  • westy73 Oct 15, 2008
    I have a DSC W30 and my batttery say's its fully charged on the charger!
    But my Camera wont power up! Any idea's?
I just had this same problem and was very frustrated. I changed the batteries and everything, but to no avail. Then out of my frustration, I tried to turn it on in every mode by moving around the dial on the top. It finally worked. Something must have just gotten a little out of whack.
Posted on Apr 04, 2008
SOURCE:
Camera wont turn on.
Make sure that you're using fully charged battery pack.
Remove the battery and reinsert it.
Try using different battery if available use AC adaptor and check..
If the issue persists with different battery, service is required
Jan 01, 2011 | Nikon Coolpix 8400 Digital Camera
My Sony VSC 1 camera is not turning on!!!! The charge went out and the camera turned off. After that it's not turning on. What do I do?
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
Feb 17, 2010 | Kodak EasyShare V1003 Digital Camera
Camera shuts off when plugged into computer wont turn on while plugged in trying to put pics on computer
The camera needs battery when connected. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NOTE The cameras LCD screen will remain black throughout the transferre.
If you're experiencing that the computer is not reacting to the camera at all try the following:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 27, 2010 | Kodak Easyshare C813 Digital Camera
When I turn the camera on, it immediately turns off. I have changed the batteries twice already. What's causing this?
Some batteries simply don't fit right in this camera. Look at the battery connections-no standard bumps and springs. Then take a good look at two different makes of batteries. Some batteries have edges arount the end that extend further than others.
Try a different brand of batteries.
Jan 10, 2010 | Kodak EasyShare C913 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Lcd will not turn on on a DSC-W50.
1. Ensure that you are using either Battery Model # NP-BG1 or NP-FG1 with the Camera.
2. Try using different Battery to determine whether the issue is with the Camera or with the Battery.
3. Try to Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists with different battery also then Service may requires to resolve it.
Aug 29, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens will not open with batteries
Try cleaning the battery contact inside the camera batteries slot.
Also test a different battery, possibly a battery pack that you tried on a different camera.
If that does not fix the problem, then there is a faulty component iside the camera, usually you get this kind of problem because of a faulty camera, or oxide on camera batteries contacts.
Dec 02, 2008 | HP Photosmart M517 Digital Camera
Powershot G7 Camera won't turn on.
Same issue happened on Saturday. Only difference was the lens cover didn't completely shut when I tried to turn it off. I turned it on then off again and the cover shut....but it wouldn't turn back on. I fully charged the battery, but nothing. Tried two different batteries.
I was going to take mine in today to Wolf Camera in CO where I bought it.
Note that the camera was fully cleaned and and a new lense added less than a month ago by Canon (through the warranty program through Wolf)
Thougths?
Did anyone get any feedback?
May 12, 2008 | Canon PowerShot G7 Digital Camera
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera turns off
1. Try the camera with a different CF card. 2. Try the camera with a different battery. Defective components don't always fail in expected ways. The battery might have enough power to "sometimes" operate some functions but not consistently. The CF card may be malfunctioning is some way that draws too much power from the camera & at times causes it to "lock-up" or shut down. If you don't have another battery or CF to try, you may be able to bring your camera into a camera store where they may have & let you try 1 of each on your camera to see if it fixes the problem. They may do this in the hopes of selling you either a new battery, CF or camera depending on which proves defective.
Jan 07, 2006 | Fuji FinePix A605 Digital Camera
Cameras Logo
125 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
