Question about Linksys Wireless-G WRT54GS Router (e125894)
Port forewarding i am trying to run a program that needs to go thru my router and guess i have to do something with the port forewarding
  • kj4axv Mar 23, 2008
    the program is tellingme the firewall on the router is not letting it thru
    Sergeant:
    Champion:
  • 427 Answers
Ok, this is very simple. All you need to know is what port number you need to forward and either TCP or UDP. (ex. 200 TCP)
Open an internet browser and enter 192.168.1.1
Enter your password.
Go to Applications and gaming. Look for port range forwarding.(by the way upgrade your firmware)
Under the program name, put what you want.
enter the numbers of the port from the start-end port option.
Select the protocol(TCP or UDP)
Select the Ip address of the programs computer and enable. (BE SURE TO SAVE BEFORE CHANGING THE PAGE)
Posted on Mar 23, 2008
I want to setup port forwarding on my Siemens Gigaset 572 router to allow FTP. How do I do this?
You shouldn't need to forward any ports to use FTP. It's like forewarding ports for HTTP or e-mail you dont do it...
Mar 15, 2011 | Computers & Internet
Idon't know what my security code is for my belkin router.
To reset your WiFi password, run the disc that came with the router, or look at the back of the router for instructions on accessing your router thru ethernet cable to reset your password. I suggest trying to run the disc first, because if you change something in the router setup that you shouldn't then you could end up with more problems. If you don't have the disc, then often router manufacturers will put info on the back of the router so that you can gain access. Look for an IP Address (Example: //192.168.2.254) If you find this, then go to a computer that is connected to the router thru the ethernet cable and open up your Internet Explorer, go to the address bar and type in the IP address as it appears on the back of the router. After this it may ask you for a Username and Password. If so, then it also will likely be on the back of the router. Once you gain access to the router's program be careful not to change anything other than the security password. Look for an area labeled Wireless Settings or something similar to that. Once you have reset or changed your wifi password, click Save or Apply if you see that on your screen, then logout of the router's program and close out your Internet Explorer.
Sep 15, 2010 | Computers & Internet
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
How to stop torrents on DNA-A211-I bsnl wifi router ? please help
If you have access to the routers control panel
(the address should be something like 192.168.0.1 or 192.168.1.1
with user names and passwords as default, access, admin and so on. Try all of them in all) There should then be a menu to the left with something about ports- click that and follow the on screen instructions.
Disable these Ports 6881-6999( on TCP if the option is avaliable)
this SHOULD stop all bit torrent access. If you want to stop bit torrent all together close all ports. It can still be run through port 80 (the default web port)
Otherwise disable program access on each specific machine that uses Bit Torrent.
Sep 03, 2009 | Computers & Internet
Cannot connect when hardwired thru router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 15sec.. after that unplug the router for 15secs then plug it back in..
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1. it will ask u the username and password, by default the username is admin and the password, just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Aug 13, 2009 | Linksys Wireless-N WRT150N Router
SPEEDTEST.NET RESULTS VERY POOR AND VARIABLE THRU ROUTER
First what type use router and you using internet firewall ya VPN
plz tell me
Mar 14, 2009 | Dynex 4-Port Ethernet Broadband Router
Port forward problem
you shouldnt need to put in a static ip. just put all the setting back to normal. Definately forward the ports. but allow the program through the routers and the computers firewall.
Dec 31, 2008 | Linksys Wireless-N WRT150N Router
Our fire station has a cat5e cable supplying internet access to our internal network from a switch in city hall. It connects a baystack 350 to their switch. If this cable is left plugged in during the...
Very likely an IP problem. The server in City Hall is most likely doing the DHCP assignments for all connected machines, and if there is a LAN server running DHCP also in the firehall, there will be a conflict, which may not manifest itself until the assigned IP leases expire and renew. If this is the case, try a router WITH DHCP DISABLED between the two systems, WAN side toward City Hall. As a quick test, disconnect the cable and run IPCONFIG on a firehouse machine. Note the IP, it should begin with 10, 172 or 192. Reboot the machine, run IPCONFIG again. If the IP comes back, you have DHCP running on something. If you see something like 169.254.???.??? you do not, in that case try hooking up a router configured just as it comes from the box. If anything in the firehouse is wireless, making connection thru a wireless router, the problem may be a simple miswire. WAN side toward City Hall and one of the ports toward your switch, don't use the other three. May need to use the uplink port or a crossover cable between router and switch. (Network admin by day, DJ by night)
Sep 11, 2008 | Computers & Internet
Changing com port numbers??
Some (older or less sophisticated) software expects a com port with a number no higher than 4.
If this is the case, try changing the GPS emulated / virtual com port in "windows | control panel | system | ports" to something less than 5.
Jun 18, 2008 | Linksys Wireless-G WRT54GS Router...
Opening ports
Hi tazz,
Got to this link. Find your router in the list. Click on it, and then click on the prgram you want to port forward for. It will walk you thru the steps. If you can't find your program, try UltraVNC, which uses some of those ports!
http://portforward.com/routers.htm
Good Luck!
Jan 08, 2008 | NetGear RangeMax WPN824 Wireless Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
