Question about Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers
I have a 1997 Jaguar XK8 and need the radio code for the original harmon cardin radio and how to reset the code as well. Thanks!
Where on the 1997 Jaguar XK8 convertible is the cabin air filter located?
It is located under the panel in front of windscreen
Jun 25, 2014 | 1997 Jaguar XK8
How to reset air bag light 1997 xk8 jag pulled fuse by mistake now light won't go out
Youll have to take it to the dealer, and trust me, I do not recommend the dealer ever, so I dont write this lightly.
Oct 27, 2013 | 1997 Jaguar XK8
Fault code list for Jaguar XK8
Hi there:
I suggest visit this LINK about Jaguar fault codes.
Hope helps.
Feb 27, 2013 | 1999 Jaguar XK8
I HAVE THE RADIO CODE, BUT HOW TO ENTER IT
if you have the radio code just turn the radio on enter the 4 numbers and the radio should just come on. Hope this helps.
Feb 09, 2013 | 1997 Jaguar XK8
I have repaired an accident damaged xk8, both airbags went off, know when i turn over the engine the ecu is saying none genuine parts to suspension & warning lights on dashboard.. how do i reset the e
I'm not 100% sure on Jags, but on a domestic vehicle you have to clear the code with a scan tool. You should be able to call any Jaguar service center and get a quick answer.
Nov 15, 2011 | 1997 Jaguar XK8
Needed: radio lock code for Jaguar XK8 which had a flat battery recently.
only way your! going to get that is at the dealer and they will want to reset it for you!
Jan 22, 2010 | 1999 Jaguar XK8
No manual for 97 xk8 ... cannot get radio code..
Log on to www.radio-code.com They should be able to help you get the code and get your radio working again, but try 0000 for now and see if that works. Good luck and Keep me posted. Be glad to help
Jun 23, 2009 | 1998 Jaguar XK8
I want to clear check engine light on 2002 jaguar xk8
go to autozone have them scan it and then clear it record the trouble code and then clear it another option is disconnect the battery both positive and negative and make a jumper wire between the 2 terminals make sure that you disconect the battery very importan
Apr 26, 2009 | 1997 Jaguar XK8
Radio doesn't work
it stays blank until you input the 4 digit code then it fires up
Dec 13, 2008 | 1997 Jaguar XK8
Need to install radio antenna on 1999 jaguar xk8
on the base of the antenna mast is a chrome nut (14mm?) unsrew that, then turn radio on , it will eject the guide cable. then insert the new cable, turn radio off and wait like 15sec then the motor will take in the new cable then put the chrome nut back on> thats it
Jul 29, 2008 | 1999 Jaguar XK8
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
192 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
