Question about Thermador DWU244 Dishwasher
Does not drain the water
It does all the cycles but at the end there is still water not drained.
  • Thermador Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 23, 2010
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Water does not drain at end of cycle
Could be drain pump , float switch, or PCB. Does it initially go thru a drain cycle when you start a cycle? Is there water in the bottom of the tub?
Oct 02, 2013 | Bosch 24" Built-In Dishwasher - SHE43R55UC...
Dishwasher doesn't pump the water out at the end of the cycle.
clog in the unit . check the drain hose. disconnect the hose then drain machineinto bucket. then check the drain pump to see if the pump is pumping or clogged.
Mar 13, 2010 | Bosch Dishwashers
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Hi
You can :
Check for hose kinks or food plugging drain hose. Start at the drain port exit
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check timer for not letting the dishwasher pause. ( not all dishwashers )
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Thermador DWU244 Dishwasher Logo
155 people viewed this question
Top Thermador Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
ray gallant
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
