Question about Digi 2.5 lb x 0.0002 lb AC/DC Digital Counting Scale, (HPCS274219)
Digital scale I have a digital scale that turns on but does not show any weight when something is placed on the scale.
    Problem Solver:
  • 19 Answers
If scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Posted on Dec 03, 2008
Tip
How to change a ip through command prompt
Netsh” is a nifty utility to change system networking settings, locally or remotely.
To run Netsh click on start then RUN and type CMD press ENTER.
When the command prompt comes up type Netsh, now you should be ready to execute commands. Simple huh. Just to warm up type “interface ip show config“ that will show up the TCP/IP network settings.
Now, how you change the IP address and Default Gateway settings? To change the Local Area Connection TCP/IP settings type the following command:
interface ip set address name=”Local Area Connection” static 192.168.10.42 255.255.255.0 192.168.1.1
on Dec 20, 2009 | Computers & Internet
How do I reset the Privilege password on a 2600? The former IT Manager left without telling us what it is, and now we're screwed.
you need a reboot and a serial console I'm afraid. Lots of places on Cisco that detail the password recovery process, it's quite complex so I'm not going to go into detail, but you need to be physically in the same room connected with a serial console cable (9600 baud) for it to work. Basically, use break to interrupt the startup, change the config register to ignore startup config, reboot , go to enable mode, copy run start, enter config mode and reset the password.
Mar 26, 2010 | Paradyne BitStorm 2600 (2611-a1-430)
Getting into codes (digibox)
I think your box is an Arnet A700C right, not a c700a
Look here!
http://www.digital-kaos.co.uk/forums/f99/kryptview-13067/
Jan 13, 2009 | Arnet Refurbished MULTIPORT 8 MANUAL DIP...
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
Digital cable box
Well the only way is too get a hacked version which is illegal.
Jun 11, 2008 | Black Box mDSL Digital Cross Connect...
Cant access the Zyxel IES-1000
Just a suggestion...try to loop-back ping to make sure YOUR still on the network. If you are have you tried tracert? The IES-1000 is an IP-based DSLAM, so you should get something back. Here is a link that may help you a bit more http://www.computerhope.com/issues/ch000444.htm
Sep 20, 2007 | Zyxel IP Express IES-1000 (91004098002)
Fujitsu laptop 6240
You can connect an external keyboard and see if the problem persists. That would rule out a keyboard problem. Also connect an external mouse to see if the system is frozen or the keyboard/mouse combo are just not working. If its a keyboard problem, chances are you either spilled something on it or the connector came loose from vibration or general use. Unscrew the keyboard and reseat the cable. See if the problem is resolved.
Aug 17, 2007 | Fujitsu (G281065802)
Computers & Internet Logo
925 people viewed this question
Top Digi Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
yoyoyugo
Level 1 Expert
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
